wait what, no oil?
Old Aug 21, 2011 | 10:45 AM
  #41
thunder98110's Avatar
thunder98110
exhaust does not smoke at all. as for oil i switched to mobile 1 vmax stuff.
Old Aug 21, 2011 | 09:07 PM
  #42
Lebbie54's Avatar
Lebbie54
I'm not trying to be a jerk or anything, but I'm glad to see someone else has my problem. I just changed my pcv valve, there was some gunk in my nipple leading to the intake. Have you looked at yours yet?
Old Aug 21, 2011 | 09:41 PM
  #43
thunder98110
i haven't checked it yet
Old Aug 22, 2011 | 01:08 PM
  #44
Lebbie54's Avatar
Lebbie54
I would, it takes a few minutes to pull the intake tube out and pull everything apart. But You might have a gunk build up in the intake nipple. I cleaned mine out and replaced the valve a couple of days ago. I havn't seen my oil drop since then. DAKZ posted something on my thread about this that a clogged PCV valve can cause oil leaks or drops with out any external leaks. The part is like $3, and it is recommended to be replaced every 80K. For $3 its worth a shot. So far has worked for me.
Old Aug 22, 2011 | 01:20 PM
  #45
thunder98110
just checked it, it looks brand new and still rattles.
Old Aug 22, 2011 | 01:25 PM
  #46
moparman_2004's Avatar
moparman_2004
so you still cant find where the oil is going if possible can you maybe pull a valve cover and see if there is oil not draining back to the pan its a far chance but wouldnt hurt at this point its hard to beleive that this much oil is disapearing and you dont see a drop
Old Aug 22, 2011 | 01:38 PM
  #47
thunder98110
last thing i need to do is a compression to tell me whats going on with the internals although the shop that installed it did one before the install and said it was within spec. and its burnt oil from day 1 so....
Old Aug 22, 2011 | 03:25 PM
  #48
moparman_2004
maybe take it back and see if they will redo there test tell them the problems you have been having with it losing oil since day one and see where the specs are now
Old Aug 22, 2011 | 05:38 PM
  #49
Lebbie54's Avatar
Lebbie54
If you do take it back let us know what they found wrong with it.
Old Aug 23, 2011 | 08:23 PM
  #50
Lebbie54's Avatar
Lebbie54
Bump trying to keep this fresh in our collective minds.
