Old Aug 6, 2015, 11:53 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
A/C evaporator leaking inside cab
Old Jun 17, 2011 | 04:46 PM
tjbmopar's Avatar
tjbmopar
thank you so much it is hard to see but we found it Thank You again Tom
Old Jun 17, 2011 | 05:32 PM
bwdakrt's Avatar
bwdakrt
No problem. Glad to be of help.
Old Sep 25, 2011 | 12:16 PM
MASCHEEF88's Avatar
MASCHEEF88
Default 2003 Dakota 3.9 V6
Had the same problem everyone is describing. Took me a while to find the actual drain tube but to see it all you have to do is is pull off your passenger side tire, on the firewall you will see a small heat sheild behind the the exaust flange pull it off and holy smokes there it is little black tube. the problem i identified is that when the ac is running the drain tube does infact do its job however due to crappy design the water has the tendency to ride the tube back toward the cabin and due to no water proof seal at all it will drip inside the truck and and soak your passenger side floor board. My fix was purchase a 1/2" 90 degree elbo got mine at home depot. local autoparts stores didn't have it. The fit will not be perfect however if you use enought PVC primer and glue the fit is fine. you will have a cut a little piece of the heat sheild away to accomodate the elbow. Ran the car and low and behold the ac drains to the ground vice inside the car. hope this helps.
Old Sep 26, 2011 | 12:53 PM
DakCC4x4's Avatar
DakCC4x4
Well dadgum i have been trying to find what the heck was causing my leak forever and i guarantee this is it. I pulled my carpet out to just see if i could find the culprit but havent had much of a drive to see it.
Old Sep 26, 2011 | 06:33 PM
98DAKAZ's Avatar
98DAKAZ
Default Dodge dose give you an elbow for the drip line
Dodge dose give you an elbow for the drip line it just fell off or a mechanic forgot to reinstall it my Dakota always had an elbow till it was worked on then it disappeared mechanic forgot to reinstall it.
If that elbow is missing it can get forced back into the cab.
Old Sep 28, 2011 | 09:16 AM
DakCC4x4's Avatar
DakCC4x4
I fixed mine last night. Boy that was a booger to get to. Note to self* make sure the engine is cooled down before attempting this lol
Old Jul 21, 2013 | 12:43 AM
lu9103's Avatar
lu9103
Default 2005 dakota
Hello guys, I'm new to the site. I just bought a 2005 dakota sxt and I'm having the same problem with my passenger floor board getting wet, also my as lines are freezing up. I would like to know if some one can take a pic on where my ac drain line is at so I can do the same thing. Thank you. And please help.
Old Jul 21, 2013 | 12:48 AM
lu9103's Avatar
lu9103
For a 2005 dakota, is this where it is located too?
Old Jul 21, 2013 | 09:29 AM
bpark8824's Avatar
bpark8824
You should probably ask this question in the 3rd gen Dakota section. It may or may not be located in the same location on a 3rd gen Dakota, I'm not sure.
Old Jul 21, 2013 | 10:02 AM
bwdakrt's Avatar
bwdakrt
Same location but probably behind some type of shield.
