ASAP driver side valve cover.
Old Jun 28, 2011 | 04:22 PM
  #51
GrnDak01's Avatar
GrnDak01
Originally Posted by moparman_2004
are these interference motors
The Haynes manual says they are. The torque for the cam sproket is 90ft lbs I believe.
Old Jun 28, 2011 | 05:49 PM
  #52
moparman_2004's Avatar
moparman_2004
well then im wondering if hes gunna have some bigger problems
Old Jun 28, 2011 | 09:57 PM
  #53
URBANRDNECK's Avatar
URBANRDNECK
So basically I have to call a local machine shop and ask if they can make me a new cam dowl pin? And I'm guessing I have to completely redo my timing?
Old Jun 28, 2011 | 10:03 PM
  #54
thunder98110's Avatar
thunder98110
yes. and if the timing chain didn't fall off then not necessarily.
Old Jun 28, 2011 | 10:07 PM
  #55
URBANRDNECK
well I think I am going to have to because the the dowl pin on the cam popped out of the sprocket after it "broke" and started grinding. Which means my timing is off and I probably just F-ed up the whole side of my engine
Old Jun 28, 2011 | 10:12 PM
  #56
thunder98110
was the sprocket off the cam when you popped the VC?
well it would have had to been, the bolts held it on. brain fart.
Old Jun 28, 2011 | 10:21 PM
  #57
thunder98110
im asking my buddy what he did with his timing when the same thing happened. ill get back to ya.
Old Jun 28, 2011 | 10:22 PM
  #58
URBANRDNECK
But thats the thing. When I pulled the VC off the cam was still attached via bolt but the dowl pin wasn't in the slot.. I know for a fact that I put it in that slot.
Old Jun 28, 2011 | 10:32 PM
  #59
thunder98110
well even if you torqued it to like 60lbs or something that dowl would still be in the slot. somehow worked loose. no clue man.
Old Jun 28, 2011 | 11:02 PM
  #60
URBANRDNECK
Yeah that's the confusing part, I have no possible idea on how that could happen
