What are the largest tires that will fit on my truck?
Old 08-03-2011, 05:20 PM
blazerhoops33's Avatar
blazerhoops33
blazerhoops33 is offline
Default What are the largest tires that will fit on my truck?
It is a 2001 Dodge Dakota Sport 5.9 L V8 Magnum Extended Cab. It has all the heavy duty packages, and is all factory. I am looking to do alot to it.. But first I would like bigger tires. Thanks
Old 08-03-2011, 05:38 PM
dodgeramguy85's Avatar
dodgeramguy85
dodgeramguy85 is offline
32's if you crank your torsion bars and 33's if you crank your bars and do a body lift
Old 08-03-2011, 06:17 PM
NickCornell's Avatar
NickCornell
NickCornell is offline
Hey I don't wanna thread jack, but I have the same question for my 03 CC 2wd with the 3.9. I've heard 30 but when I look at my truck I think it sits very low. Its about time for new shocks up front.
Old 08-03-2011, 06:30 PM
dodgeramguy85
You can do lift coils stock I think the biggest is 30's stock
Old 08-03-2011, 08:25 PM
magnethead's Avatar
magnethead
magnethead is offline
I've got 275/65/16's on my truck...they fit, but it aint by much...tread blocks are a little chewed from the top of the fender, but if you don't bottom out, that's a null issue...
Old 08-03-2011, 09:59 PM
blazerhoops33
Thanks. How do you crank the torsion bars??
Old 08-03-2011, 10:07 PM
thunder98110's Avatar
thunder98110
thunder98110 is offline
its a 15/16th bolt at the rear of the torsion bar.
Old 08-03-2011, 11:17 PM
dodgeramguy85
To add to thunders post jack up the front end make sure both ends are off the ground that way you can measure it and check the other side. I did like 20 turns on mine and that got me like 2 inch. They also reccomend to get your truck aligned afterwards but if your getting new tires just wait till you do
Old 08-03-2011, 11:21 PM
blazerhoops33
So if I crank it up tomorrow, but get new tires in about a month, am i ok to drive without it aligned during that time?
Old 08-03-2011, 11:23 PM
thunder98110
20 turns???? i thought 1 turn was 1/4 inch???? guess not!
since your getting new tires, yeah it probably wont do any damage. but its your call.
Quick Reply: What are the largest tires that will fit on my truck?
