Lift install ?'s
Old Aug 12, 2011 | 11:20 AM
hanleysh's Avatar
hanleysh
Default Lift install ?'s
Ok I'm installing a 2.5" torsion key lift this weekend and was wandering if anyone has any pointers... Never messed with torsion keys(or IFS) before. I searched the forum for some help and came up empty handed.. A step by step would be awsome or a little info to get me in the right direction. Also doing an add-a-leaf in the rear, just one ?, will I need new u-bolts? Looks like I've got a little more than 1" of threads left under stock ones. (03' QC 5.9) Only reason for the lift is I found a set of 315/75/16's for 40$/tire, cheaper to lift it a little more and buy those than buy new 305's Thanks very much for any help
Old Aug 12, 2011 | 11:50 PM
Blaze10's Avatar
Blaze10
well i see you have 3" body lift already so yes 315s will fit after the t bar lift, i would help you out but i had a shop do my lift for 100 bucks i did 2.5 front and 2" rear lift plus my body lift.
Old Aug 13, 2011 | 05:14 PM
hanleysh's Avatar
hanleysh
thats what I was planning, add-a-leafs in the back and 2.5" keys up front...did the add-a-leafs today in about 45 minutes, probably gonna venture into the keys tomorrow if I can find a little more info online first
Old Aug 14, 2011 | 10:12 PM
hanleysh's Avatar
hanleysh
ok...so I made attempt #1 with the torsion keys today.....unloaded them, removed the bolt the whole way and cant get the key far enough out of the crossmember to get it off the bar.....has anyone here done the keys themselves? Need I remove the torsion bar from the front? Sorry new with torsion bars and IFS all together, need a little help
Old Aug 14, 2011 | 10:18 PM
Rakaric's Avatar
Rakaric
I tried mine a year ago and the key was rusted and frozen. Tried a bunch of techniques and none of them worked. So I just cranked it up all the way instead of putting in the new keys.
Old Aug 15, 2011 | 02:54 PM
hanleysh's Avatar
hanleysh
my keys are loose on the back of the bars, just not enough room to get them off the bar in the crossmember, tried droppin the tranny crossmember to get a little more wiggle room, not enough. Next question is how do I remove the bar all together? remove the lower control arm and sway control?
Old Aug 15, 2011 | 03:17 PM
hanleysh's Avatar
hanleysh
and not to hijack my own thread but... Blaze, I see youre from clinton county...ever cruise around Lock Haven in that rig? Looks pretty familiar
Old Aug 17, 2011 | 12:39 AM
URBANRDNECK's Avatar
URBANRDNECK
what I did is took a pry bar to the torsion bar and pryed it down so I could have someone else take the keys off and put the new ones on
Old Aug 19, 2011 | 04:24 PM
hanleysh's Avatar
hanleysh
sounds easy enough, going to give it another try here tonight, hoping for some better luck, I'll let you guys know how i make out
Old Aug 20, 2011 | 04:15 PM
hanleysh's Avatar
hanleysh
thanks man...worked out pretty good only I didnt have someone to swap keys for me so instead I used a porta power to pry the bars down and made the swap. Success! Now for an alignment and 315/75/16's
