ctm questions
Old Aug 13, 2011 | 04:13 PM
moparman_2004's Avatar
moparman_2004
Default ctm questions
on my truck im gathering the parts to convert it to power windows/locks/mirror then the overhead console with auto dim mirror found a few people that have done it already and said its pretty much a plug and play setup once you get all the parts the biggest of which is the ctm (time and alarm module) i just wanna make sure this is the module that controls the windows and locks before i go ahead and order the part the parts guy at the dealership wasnt a whole lot of help but did find out it was the same for 2002-2004 trucks which helps a bit so does any body have a list on what all the module controls
Old Aug 14, 2011 | 06:02 PM
moparman_2004
i need to see if a few of you guys can look at your ctm this part number is supose to be for 2002-2004 dakotas but the parts manager at dodge didnt know a whole lot does anybody with a quad cab have this part number 56049072al the L may not be the same is its the newest version ive seen k,e,g,h i believe i just need to see if there as specific as ecm's are thanks
Old Aug 14, 2011 | 06:12 PM
magnethead's Avatar
magnethead
The last 2 letters are the firmware versions.
Looks to be the same CTM as a durango, as well.
http://www.factorymoparparts.com/56049072ag.html
Old Aug 14, 2011 | 06:38 PM
moparman_2004
ok so can u mix and match firm ware versions or are they specific to your vechical dodge saying i need al can i run the ag version u posted
Old Aug 14, 2011 | 06:41 PM
magnethead's Avatar
magnethead
al just means yours had a very new firmware on it. As long as the numbers match is all that matters
Old Aug 14, 2011 | 06:42 PM
moparman_2004
i looked on there these are the diffrent versions of the same part number
ag,ai,ak,al
Old Aug 14, 2011 | 06:43 PM
moparman_2004
nice the one listed here is only 80 bucks http://www.factorymoparparts.com/56049072ak.htmlcan the dealer update it
Old Aug 14, 2011 | 06:56 PM
magnethead's Avatar
magnethead
doesn't need to be updated, will work as-is. Nobody's really sure what the changes are, but they are interchangable.
Old Aug 14, 2011 | 07:25 PM
moparman_2004
ok thanks for the info that helps out alot on trying to find one cheaply priced
Old Aug 14, 2011 | 08:25 PM
magnethead's Avatar
magnethead
you might try calling several dealers. I usually call no less than 5, just to make sure that all 5 agree (but never tell them you called another dealer- play dumb to each one). You never know when you might come across a tech that's done it before.
