My engine hates me
Old 08-18-2011, 03:20 PM
URBANRDNECK's Avatar
URBANRDNECK
URBANRDNECK is offline
Default My engine hates me
I have been having some engine trouble for the past few months and my mechanic looked everything over, and everything was ok... start it up and BANG. So Mr.Piston met Ms. Valve and they got it on... Hard... So in a nut shell my pistons are toast. He suggested that I would buy a used engine and install it as it would be cheaper than fixing up mine. Can I take any 4.7L? or does it have to be my model year? Any Help is great guys
Old 08-18-2011, 03:24 PM
moparman_2004's Avatar
moparman_2004
moparman_2004 is offline
well you need to match up tone wheels 16 tooth for 3 plug ecm and 32 tooth for 4 plug i believe is how it is but maybe its time you do a H.O. swap
Old 08-18-2011, 03:29 PM
URBANRDNECK
yeah I was thinking about doing a H.O swap or trying to put in a 08 motor but I wasn't sure if that would be way over my head or not
Old 08-18-2011, 03:34 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
Lightbulb engine in a crate
I dont know what you want to spend but you can get a rebuilt engine for about $3K to $4K from places.
How many miles on yours if over 160K you need a rebuilt engine everything is just old and tired redy to give it up like the valve did.
thunder98110's Avatar
thunder98110
thunder98110 is offline
do an HO swap. if you did an 3G motor swap you will need to change tone rings.
motor swap is going to cost you about 2500-3000k. thats what i ran me. the HO is so worth it man, the power is awesome!
Wait you have the 04! you already have the 4plug pcm which is ngc, so you could do a 3g swap.
Old 08-18-2011, 03:47 PM
URBANRDNECK
So if I do a H.O swap would I need the wiring harness? or could I swap everything
Old 08-18-2011, 03:54 PM
moparman_2004
http://www.spaldings.com/parts.htm they have a 08 4.7l out of a durango for $1850 with 33k miles
http://cgi.ebay.com/ebaymotors/Engin...item1c1e10d9e7
about the same price shipped and about the same miles im guessing 36 is 36k
Old 08-18-2011, 03:59 PM
thunder98110
plug and play. no wiring harness just make sure you have the 4plug pcm and you are set.
Old 08-18-2011, 04:56 PM
URBANRDNECK
Ok I'm heading to the junkyard tomorrow to see if I can find anything good local, otherwise that ebay ad looks good and its got really low miles.
Yup I have a 4-Plug PCM
Old 08-18-2011, 10:27 PM
dodgeramguy85's Avatar
dodgeramguy85
dodgeramguy85 is offline
Hemi swap!!!
Quick Reply: My engine hates me
