Need some Electronic Help
If you have not yet found the correct antenna, this one should fit the fender angle:
http://www.metraonline.com/part/44-CR88
Autozone and Advance both sell Metra products. Either one of those or a good car audio shop may be able to order it in for you if they don't have it in stock. It should not be too expensive, maybe around $20.00.
Jimmy
Jimmy
I know how you feel your not alone or they post about help they need and you never see them again
dont give up ,people tend to be self absorbed and forget politness .i own a 03 dakota ,and an 07 ram,i recently had my dakota broken into ,the lowlifes tried to steal it and smashed the steering colum and they broke the imobiliser,i purchaced a new one,$180.00 and installed it to find that i still cant start the truck,do you know why?,
I will stick it out
Never thought much of forums most are just gab or bitch sounding boards for egos.
I do like this forum most egos are kept in check and informative help is offered to all that participate without the usual bad stuff.
So most of you know my bigger text is because I’m nearly blind the bigger text helps me to see.
Rover, I think the dealer needs to program the pcm for the new immobilizer.
