leak pwr steer fluid
Old Aug 21, 2011 | 10:48 AM
willardg's Avatar
willardg
Question leak pwr steer fluid
My 2001 std cab ,2 wd, 6 cyl.is leaking pwr steering fluid ,still.
I replaced the pwr steering pump, and both hoses. Its apparently leaking out the steering mech. (Does any one know) Where can I look. Are there any seals that can be replaced.? Or should I start looking for a replacement steer geer assembly :/
Old Aug 21, 2011 | 11:29 AM
00DakDan's Avatar
00DakDan
Section Moderator
Look at the bellows on the rack. Do you see signs of fluid?
How's the power steering pressure switch?
You should see some signs of a leak.
Old Aug 21, 2011 | 11:35 AM
98DAKAZ's Avatar
98DAKAZ
Smile power steering pressure switch
That was my leak took a bit of sluthing to get the answer.
power steering pressure switch was the leak It had gone bad it wasnt louse it just started leaking so it had to be replaced.
Old Aug 21, 2011 | 01:02 PM
01KotaQuad's Avatar
01KotaQuad
i was about to say check that... mine did the same and was constantly leaking and it was the power steering sensor...
Old Aug 21, 2011 | 01:44 PM
Dakotaquad's Avatar
Dakotaquad
there should be a power steering sensor up top check it out i beleave it is the pressure line sensor. cause i had a leak to i changed the hose and it was still leaking then i checked the sensor and pulled it out and noticed the sensor had a minor crack in the fitting and was still leaking so i changed it and no more leak.
Old Aug 21, 2011 | 03:20 PM
willardg's Avatar
willardg
thanks I'll check sensor. NO sensor lite on board, so maybe its defective as mentioned.
Old Aug 21, 2011 | 04:12 PM
01KotaQuad's Avatar
01KotaQuad
it would just throw the check engine light... but it'll come and go
Old Aug 21, 2011 | 04:19 PM
98DAKAZ's Avatar
98DAKAZ
Default nothing on dash
My truck had no problem codes poping up it just leaked
Old Aug 21, 2011 | 06:48 PM
00DakDan's Avatar
00DakDan
Section Moderator
Mine too, it just leaked, no codes.
Old Aug 22, 2011 | 09:53 PM
willardg's Avatar
willardg
Thanks guys for replies
