Connect radio to fuse box
Old 09-01-2011 | 11:09 AM
willardg's Avatar
willardg
Default Connect radio to fuse box
I want to acess the fuse area for a 5v direct connection for a radio/cd player.
Need help here to connect.
*pics would help
Thanks ahead
Old 09-01-2011 | 01:11 PM
00DakDan's Avatar
00DakDan
Section Moderator
There is no 5v connection at the fuse box, it's a 12v system.
What year?
You can use a fuse tap to get power to your adapter/converter.
Old 09-01-2011 | 01:17 PM
willardg's Avatar
willardg
2001 2wd, std cab
3.9 L
Old 09-01-2011 | 02:31 PM
dodgeramguy85's Avatar
dodgeramguy85
Well first off explain what you are trying to do we might have a better solution for you
Old 09-02-2011 | 07:05 PM
moe7404's Avatar
moe7404
its easy to build a circuit to reduce 12 v to 5 v. get a lm338, or lm317. the lm317 regulaters are easy to use. you can get a lm317 one at radio shack, BUT the diagram from r/s is not right. get a diagram off the internet. its best to use a lm388 the diagram is the same for both.
