4.0L Throttle Body for your 2.5L has someone done this?
4.0L Throttle Body for your 2.5L has someone done this and is it worth it?
Link if it works is here http://www.4x4wire.com/jeep/tech/engine/throttlebody01/
It’s in the planning stage
I probably won’t do it till next year but I’m planning it out… already priced a used throttle body but will now need a new air filter system and other things plus I want to R/R my heads at same time new gaskets port the heads maybe custom valves if available haven’t done this stuff in many years so I’m taking my time.
Got it!
Got it!
I did the swap on my son's 1999 RC Dakota. There is a bit of difference on the top end, but remember there isn't much power to begin with, so you won't feel a kick in the seat change. It's only half an engine.
The two TBs have a mounting tab on the bottom that has a mating hole in the manifold - but they are in different spots for each TB/manifold. You'll have to file the tab off the 4.0 TB before it'll fit onto the 2.5 manifold. Get a big, sharp metal file and take your time. Make sure not to bugger up the TB's mounting surface. With a new gasket it'll seal just fine.
I don't know if pre-00's are different, but when I did mine the tab was on the AIS motor mount/adapter thing(idk what its called) which bolts onto the side of the tb and all I had to do was swap the mount from my 2.5 tb to the 4.0 tb. If I have time today I'll take my tb off and take some pics what I did.
Trending Topics
