Blown out brake line :(
Old Oct 23, 2011 | 10:03 AM
Dakotaquad's Avatar
Dakotaquad
Default Blown out brake line :(
well yesterday sucked cause i was going to work i blown out my brake line. at about 8 pm last night after my work shift i finally had a chance to look at the line. And what i found was not good the steel line that runs along the frame blew out from rusting. So now i need to remove that dam thing which is going to be a party in a half. Now my question is would u guys replace it with another steel line or go with a teflon steel braided hose ??
Old Oct 23, 2011 | 11:28 AM
00DakDan's Avatar
00DakDan
Section Moderator
Replace it with the hard steel line.
Old Oct 23, 2011 | 11:51 AM
Dakotaquad's Avatar
Dakotaquad
ok well i know a place that can make it in SS but they not open till monday.
Old Oct 23, 2011 | 04:16 PM
dodgeramguy85's Avatar
dodgeramguy85
Hard steel line, They are cheap and take at least 10 years to rust out again. I put all new ones on my truck after mine blew and 2 years later still no rust has formed on them. That is in the mtns of pa where they salt the crap out of the roads all the time.
Old Oct 24, 2011 | 12:06 AM
98DAKAZ's Avatar
98DAKAZ
Exclamation aluminum?
My brake lines look aluminum to me could they be or do they just look like aluminum?
The connection blocks look aluminum also.
1998 Dakota
Old Oct 24, 2011 | 12:13 AM
moe7404's Avatar
moe7404
be sure to use anti-seize compound on the tubing line nut. 25 years later you will be glade you did. al ? never heard that, but could be. i think if it was on my truck i would be praying a lot. could it be cad plating? the color of cad is like al.
Old Oct 24, 2011 | 08:44 AM
crateampsrock's Avatar
crateampsrock
1998 Dakota
trust me...they just LOOK aluminum...lol
Old Oct 24, 2011 | 07:09 PM
98DAKAZ's Avatar
98DAKAZ
Exclamation well blocks are aluminum
well the blocks are aluminum is that normal or strange?
Old Oct 24, 2011 | 07:41 PM
00DakDan's Avatar
00DakDan
Section Moderator
The "blocks" are aluminum, that's normal. Aluminum would be too soft to make brake lines out of though.
Old Oct 24, 2011 | 07:47 PM
98DAKAZ's Avatar
98DAKAZ
Talking Ok fine with me
Ok fine with me
