Dodge Dakota transmission
Old Nov 23, 2011 | 06:28 PM
dusty123's Avatar
dusty123
Default Dodge Dakota transmission
thanks
Old Nov 24, 2011 | 08:28 AM
New 2 Dodge's Avatar
New 2 Dodge
Hey,
I have the same truck - same issue. I don't think it's the transmission so breath a sigh of relief. I am thinking it may be a U joint issue and I will be swapping mine out this weekend. I will let you know if this does it.
Old Nov 24, 2011 | 11:45 PM
timmay's Avatar
timmay
How many miles dusty?
Old Nov 25, 2011 | 01:49 PM
dusty123's Avatar
dusty123
thanks
Old Nov 25, 2011 | 10:54 PM
master tech's Avatar
master tech
Site Moderator & Tech
Replace the torque converter. This was causing your rumble sound, the torque converter is going into lock up and after its been in lock up for a short time. It starts to rumbler.
Old Nov 25, 2011 | 11:09 PM
New 2 Dodge
how much for a new torque converter and how big a job?
Old Nov 26, 2011 | 04:14 PM
New 2 Dodge
Its fixed. Replaced the u joints for the rear driveshaft. No more shudder when starting from a dead stop and no more vibration/ noise when you hit 40-50mph. The u joint going to the diff wasnt too bad but the front one had a bearing cup with all the needles gone. The joint felt good after a physical examination when the driveshaft was on the truck but after I took it off, you could tell the joint was bad.
Old Nov 28, 2011 | 08:18 PM
stonemaster's Avatar
stonemaster
u have described my problem exactly, but let me ask u a ?, was the shudder worse when u went uphill from a dead stop ???
Old Nov 28, 2011 | 09:52 PM
New 2 Dodge
I am not sure about the uphill but worse when you stood on it as opposed to starting off easy. For $25.00 and a couple hours labor - you will have at least new u joints. I did a step by step on another thread. let me know if you need anything.
Old Nov 28, 2011 | 10:08 PM
stonemaster
yep, thats the ticket,
when I turn out of my driveway going uphill its bad, when i turn out going downhill its barely noticeable
point me to the thread and thanx
