2001 fog lights not working?
Old Feb 9, 2012 | 11:49 PM
  #21
aircruiser's Avatar
aircruiser
Tried it with bulb out and same results. Relay clicks and dim light. I still don't get why the relay clicks though.
Old Feb 10, 2012 | 09:35 AM
  #22
00DakDan's Avatar
00DakDan
Section Moderator
The relay should only click on and off with the switch.
When you say "clicks" do you mean repetitive clicking?
Check fuse "H" in the PDC. Make sure there is no corrosion. It feeds the relay and the fog lights. The ground for the relay is via the PCM, that's how it turns on the fog lights. You can also swap relays around to see if the trouble follows.
Old Feb 10, 2012 | 01:34 PM
  #23
aircruiser's Avatar
aircruiser
When I touch the ground jumper, it clicks and then when I take it off the bumper, it clicks. It's not constant just when I touch it and again when I pull it away. I will check the fuse and try swapping relays and post back thanks
Old Feb 10, 2012 | 05:58 PM
  #24
aircruiser's Avatar
aircruiser
Ok guys still got the relay clicking when I jump the ground to the bumper. So here's some pics, I don't know where these grounds are but here's the front of the truck:
Is this the upper rad support that is supposed to have the ground on it?
The plug
Here's behind the bumper in the fog lights location
Here's the passenger's side
It goes under this splash shield
Here's a pic inside the splash shield
And this is the ground area for the battery..anything look odd? I am not sure never dealt with the wiring on these trucks before
I bought the truck with an aftermarket switch already in the dash that looks factory so I might just wire them to that. I was gonna wire up some fogs behind the grill but I might just wire them up seperate with a fuse.
