Exhaust Question
Old Feb 13, 2012 | 01:42 PM
vimnjicki's Avatar
vimnjicki
Default Exhaust Question
I'm swapping out the V6 for a V8 and I've gotten to the point of making sure the dumb thing can be smogged so I need to know how many catalytic converters there are on the V8 model of a '97 Dakota Sport Extended Cab 4x4 and, additionally, how many O2 sensors there are also. By the way, I live in Southern California. Thank you for any information.
Old Feb 13, 2012 | 02:46 PM
thunder98110's Avatar
thunder98110
you should have 2 pre cats, one off of each manifold and then 1 main cat. one 02 sensor per pre cat, and one before the main. thats what mine is like.
Old Feb 13, 2012 | 03:36 PM
DakinUK's Avatar
DakinUK
A '97 V8 will be the 5.2, not the 4.7, so COULD be a different set-up.
Old Feb 13, 2012 | 05:03 PM
chris1996's Avatar
chris1996
well i have the v6 and have that setup
Old Feb 13, 2012 | 06:09 PM
gnelson49's Avatar
gnelson49
I have the 5.2L in my 1998 Dakota, it has a single cat and a pre- and post-cat O2 sensor. Mine is federal emissions, not sure if California emissions requires a pre-cat on each pipe off the manifold?
Old Feb 13, 2012 | 06:36 PM
UWAdventurer's Avatar
UWAdventurer
Mine has one cat and one pre cat and one post cat O2 sensor.
Old Feb 13, 2012 | 10:47 PM
vimnjicki's Avatar
vimnjicki
Before the swap, the V6 had one cat after the Y-pipe with a pre and post O2 sensor. The Edelbrock header/Y-pipe setup i bought for that year with a V8 has the same setup. UWAdventurer, you dont happen to live in California, do you? Thanks for the replies.
Old Feb 14, 2012 | 09:14 PM
hanleysh's Avatar
hanleysh
Mines an 03 5.9 and it has one cat with sensors before and after it....I live in pa though... I'd check ur local regs and go with what they say
