Paranormal activity?LOL
Old Feb 19, 2012 | 09:51 PM
pumpkinheaver's Avatar
pumpkinheaver
Default Paranormal activity?LOL
Ok here's the deal. I was driving my '01 Dakota last night and noticed my dash and headlights flickering every few minutes. Then it got worse every 30 seconds or so. Finally it started really flickering every few seconds. Then my horn would spontaneously honk and the wipers would jump every once in a while. I had headed to home by this point and then I lost my headlights!!!! Drove the rest of the way home with my hazard light on. Pulled in the garage and shut her down. It would not start back up. Today I pulled the battery terminals and cleaned them, and she started right up. Test drove it with lights radio etc... on and had zero problems. Tonight it's doing the same thing all over again. I'm guessing PCM but is there anything else I should check first? Fuses, shorts etc?
Old Feb 19, 2012 | 09:58 PM
huseman808's Avatar
huseman808
Id try the Central Timer Module. I think that controls some of that stuff
Old Feb 19, 2012 | 10:21 PM
chris1996's Avatar
chris1996
Lets call the gosthbusters..!!! haha no probably a bad earth I would check terminals and connections
Old Feb 19, 2012 | 11:04 PM
SMjunkie's Avatar
SMjunkie
Yea, Central Timer Module comes to mind...
Old Feb 19, 2012 | 11:13 PM
pumpkinheaver
I just had another thought. About a month ago I noticed that when I hit my key fob button to turn my alarm on that the heaadlights didn't blink as they should. I was meaning to get around to fixing it one of these days just never had the time. I'm wondering if this doesn't something to do with the problem. The horn and lights are tied into the alarm system. Just a thought. I'll check it out on the morning.
Old Feb 20, 2012 | 08:04 AM
chris1996's Avatar
chris1996
Better check that maybe is a bad connection
Old Feb 20, 2012 | 01:31 PM
pumpkinheaver
I found a broken wire and fixed it, now the lights flash when I turn on the alarm as they should. I drove the truck a few miles and everything seemed OK, thought I had found the problem. Turned into my drive way and the lights started blinking and the door dinger went off. Guess it isn't fixed!!!!
Guess I need to find the module suggested above.
Can I go to a junk yard and get one? School me on what I need to do.
Old Feb 20, 2012 | 04:56 PM
huseman808's Avatar
huseman808
https://dodgeforum.com/forum/2nd-gen...knowledge.html
Check this thread out. Sounds like you can just pick one up from a junkyard.
Edit:
The CTM should be in the drivers kick panel with 3 plugs on it. Just so you know what to look for.
Good luck
Old Feb 20, 2012 | 06:38 PM
pumpkinheaver
The wire that was broken was a wire to the alarm that was tied into a wire leading to the module in the above picture. Do you think that when the wire broke it did somethin to the module.
If I picked up the module from the junkyard would it have to be from the a truck with the same engine and year or would any of them work?
Old Feb 20, 2012 | 10:14 PM
dodgeramguy85's Avatar
dodgeramguy85
It would have to be from the same truck with all the same options power locks,windows and so on. Your keyless entry would need reprogrammed at the dealer for it to work
