No Reverse Lights
Old Feb 27, 2012 | 05:07 PM
dan0614's Avatar
dan0614
Default No Reverse Lights
I have a 2002 Dakota with a 5 speed manual and the reverse lights are not working.
I don't believe its the bulbs because i couldn't imagine all of them going bad, and the dome light still works.
I replaced the fuse and that didn't fix it (swapped the one from the cigarette lighter and reverse lights, and the cigerette lighter still works)
Any thoughts on what could fix this.
Thanks
Dan
Old Feb 27, 2012 | 06:34 PM
00DakDan's Avatar
00DakDan
Section Moderator
It could be a bad backup light switch.
You should find an electrical connector on the passenger side rear of the transmission. You could just jump the switch and see if they work.
Old Feb 27, 2012 | 10:50 PM
dan0614's Avatar
dan0614
Thanks, I'll check it out tomorrow what its not so dark.
Old Feb 28, 2012 | 09:54 AM
crateampsrock's Avatar
crateampsrock
or you could....check the bulbs....
Old Mar 17, 2012 | 02:50 PM
dan0614's Avatar
dan0614
It's been a couple of weeks, but we got some great weather here in upstate NY, so today i finally crawled under my truck and replaced the back up light switch. Both reverse lights are now working. Thanks for all the input.
Old Mar 17, 2012 | 03:04 PM
00DakDan's Avatar
00DakDan
Section Moderator
Glad you got it.
Old Mar 25, 2012 | 10:50 AM
bythefireplace's Avatar
bythefireplace
Just a heads up. Had bad backup switch in transmission. After replacing switch, light worked for about a month, then started blowing fuse. Traced it to the new backup light switch shorted out to ground.
Old Mar 25, 2012 | 09:05 PM
moe7404's Avatar
moe7404
i have a paper 2001 dakota FACTORY service manual. send me your street address and i will, copy and, send the parts of the 42 or other trany to you, that you need moe7404@gmail.com
