CAI help MPG?
#83
This is my CAI. https://dodgeforum.com/forum/members...0&ref=gnr-prev
Regardless of if it's above the exhaust manifold, it allows more air into the engine through the improved filter. Any replacement of the stock air filter is an improvement. Hell, even the K&N drop in filter will work better than stock.
#84
#85
#86
There have been a few... and getting cooler air from outside the truck is a true CAI will actually do a lot better than just sitting in a hot engine bay..
I'm working on making a Ram air but probally going to use the factory air box to start off with. unless i find something better. because I want to be able to run a snorkel and have interchangeable tubing. .
#87
i was thinking about just using flex duct for a dryer vent and just putting a 90 or so on the bottom of the k&n shield. The bottom of the shield is open but I was also thinking about closing that off buy I may just buy a sheet of sheet metal and run the flex from the grill to that and then just screw it the the plate i put on the bottom of the heat shield. Its the aluminum flexible duct not the standard flex duct
#88
I'm sure it would work but then at the same time I kinda want to make it look good; probably will be going with Schd. 80 pipe :X there are a few items i seen there in the plumbing section that might just work out nicely but I'm finding a few ram air inlets that can be used, im still looking though.
Now that I have a new MAP sensor and the truck seems to be doing a little better with the new MAP sensor; I'm moving forward full throttle again with this project i scraped about a year and a half ago..
#89
You'll be doing yourself a solid by moving away from the stock air intake.
As far as the choice between a CAI and a TB; it will depend on how you drive and what you want to achieve. jondakotaguy is a really good guy to talk with about this kinda thing. Here is a good link to check out:
https://dodgeforum.com/forum/2nd-gen...r-cleaner.html
jondakotaguy better explained the difference between a CAI and TBs
As far as what I have, I run an Airaid 300-107 - it came with my heap when I bought it. it works well enough for me. It didn't come with an air box though. I want one but I have not acquired or fabricated one yet one as of yet but all is good so far with it...
TBs are a nice, sleek and straight forward/ no B.S. air intake. I would be open to trying out one of those.
Hope that helps!
Hope that helps!
#90
I have a air intake and a tb spacer and for me I have noticed a performance difference. It seems to me to have more get up and go as well as top end power.
macgollabhride if you want the factory air box I have one posted in the classifieds with a k&n drop in as well as a spare fram air filter that I am trying to sell.
