Power Issue/Starting Issue?
Old Mar 23, 2012 | 12:50 PM
5hundo's Avatar
5hundo
Originally Posted by jmich
I picked up the post shims while at work today. I don't think they are wrong size, I just think the terminal is beat and old. It moves ever so little but darn if it doesn't seem to affect the starting. I will shim it today after work and start looking for the right oem positive batt cable replacement.
Joel
You can also bend the ends of the terminal apart and file down the inside of the terminal until it can get a good purchase on the post. Just make sure you use a well chalked file so your teeth don't clog.
Glad your problem turned out to be a simple one! Always good to see that...
Old Mar 23, 2012 | 07:48 PM
jmich's Avatar
jmich
I installed the shim on the positive post, tightened her down good and all seems well. I also hand wiggled the positive wires and the lights did not go out. Thanks for all the input, gang!
Cheers, Joel
