Cleaning the throttle body tomorrow!
Are there any precautions I need to take or any common problems encountered? I plan to 1) disconnect negative battery cable 2) unplug necessary sensors 3) remove cables 4) remove bolts. Let me know if I missed anything besides the obvious. Also what kind of improvements should I see? Thanks in advance guys
this may help
this may help I belive this is for a V6 but cant tell but everything is close to the same all same parts.
With Pic's http://www.dakota-durango.com/forum/...d.php?t=105835
Well having 185,xxx miles on the truck, this was probably it's first throttle body cleaning. TBDirtytop.jpgTBCleanTop.jpgTBbottomdirty.jpgTBbottomclean.jpgThank you Dak for your link. It walked me through every step. I appreciate it!
Anyways;
As a precaution, I'm replacing my MAP sensor sometime this week whenever it arrives in the mail. I knew, full-well, that it would be a good idea to clean out the throttle body and replace the gasket but looking at it under my hood, with the cables, connectors, and the general unknown (in my mind) was very off-putting to me. The step-by-step photos, in that link were exactly what I needed for me to get comfortable with the idea if tackling it myself.
Thanks again for that.
l
Trending Topics
I cleaned my throttle body this afternoon, replaced the gasket and replaced my MAP sensor.
It was incredibly easy to do; I'm mighty proud of myself . It wasn't as dirty asI had expected but I cleaned it anyways. I used that Sea Foam stuff and, except for where the throttle plates pivot in the assembly, I hardly had to use a toothbrush - I mostly used a rag.
My Dakota feels like a totally different truck now - for the way better! The idle is smooth as glass, it's quieter and it doesn't feel like its struggling when I accelerate. I'm totally stoked!
I do have a newbie/novice question:
I did remove both wires to the battery and now the CEL is off. I doubt cleaning the TB and replacing the MAP would have actually corrected my CEL issue - it would be great if it did but seriously doubt it.
I imagine that you have to drive so many miles in order to re-trip the CEL? If so, around how many miles is that? I drove around for a couple miles after the work that I did this afternoon but the light never came back on.
Well disconnecting your batter will temporarily clear your CEL; but if the problem still exists that has tripped it; it will return.. when it does go to Autozone or somewhere that will pull and tell you the codes for free. and then bring the codes here to the forums and we can sifer through them in the most logical order sometimes they will have multiple codes.. one sensor can trigger 3 codes.. for each sensor that depends on the first.. LOL..
But anyways there is nothing wrong with cleaning the TB. When i did mine i cleared the little reverse to Drive die problem. But i screwed up the IAC cus i pushed on it and turned it LOL now it clicks..
I just replaced my map from a guy on E-bay that i got a New delphi (Great manufacture) for 21 bucks with shipping. Got it today installed and i can already feel a slight difference.
Next is replace the IAC and the solinoids in the tranny that is causing a float shift from time to 2nd to 3rd.
