Stripped spark plug
#21
Found some info on the sparkplug tubes
http://www.dakota-durango.com/forum/showthread.php?t=57728
http://www.dakota-durango.com/forum/showthread.php?t=44583
https://dodgeforum.com/forum/dodge-stratus/284533-spark-plug-tube-remove-2-5l-v6.html
#22
I didn't get to work on the cable today - it was raining pretty bad all day here. Hopefully tomorrow?
Thanks a lot for hunting down those links for me. I figured-on those tubes being press fitted into the back-side of the heads - now that I've watched the video, it makes sense that they go through to the block in order to keep the oil outta there. I'm on my own if I want to take on removing the heads so, I'm gonna have to leave it and keep my fingers crossed that the plug doesn't crap-out anytime soon.
...As much as it's going to bother me that I have to leave it.
Thanks again!
Thanks again!
#23
#24
#25
That clears my nagging thought of why the sleeve/tube/heat shield has the gap down the side rather than a contained tube construction.
Considering my predicament, I would still have to remove the head to get the plug out.
This is a help to me.
I appreciate the help 00DakDan!
#26
I more-or-less got another idea of what to lookout for. That video still helped me out - seeing the process of assembly/disassembly makes it more realistic for me to do... but dealing the corrosion through that is a whole different matter.
Either way, I cannot get that plug out as things stand and there's no chance that I'll be able to yank the heat shield out with the plug impeding the whole process. I have no other choice than to remove the header.
#27
If thats it then
If you are going to remove the heads you may as well get them redone and gain back some power and look for some junkyard exhaust headers to replace those rusted to hell headers.
Getting those off may be just as hard as the sparkplug tube so either way you have some hard work coming your way.
#28
#29
#30
