Long drive with a trailer. Problems?
Old Apr 24, 2012 | 07:08 PM
Kyguylal's Avatar
Kyguylal
Default Long drive with a trailer. Problems?
I need to take a uhaul trailer down from Massachusetts to the west Virginia line. Fully loaded, it'll only be around 1200 pounds.
I bought a hitch receiver and the wiring. I have a 5 speed with the 3.21 axle ratio. Will I blow my transmission, or run into problems?
Old Apr 24, 2012 | 08:00 PM
00DakDan's Avatar
00DakDan
Section Moderator
Smile
Shouldn't be any problems once you get through Hartford. I hate that part of the trip.
What engine? Year? 2 or 4wd? Cab style?
3.21 really isn't the best for towing. You may need to downshift a bit and use 4th up hills.
Old Apr 24, 2012 | 09:02 PM
moe7404's Avatar
moe7404
if you have time, do this. drop the trans pan take the fluid out. put it back to gather. then add rear end grease to the trany.. i know it sounds crazy, but it works. i know a guy with a race car with with tractor fluid in the trans.
Old Apr 24, 2012 | 09:40 PM
Kyguylal's Avatar
Kyguylal
It's a 2000 3.9 l v6. 2wd regular cab
Old Apr 24, 2012 | 10:49 PM
00DakDan's Avatar
00DakDan
Section Moderator
How much weight will you have in the bed?
Old Apr 24, 2012 | 11:09 PM
Kyguylal's Avatar
Kyguylal
Just. The weight of my tool box and ladder racks. So around 50 pounds
Old Apr 25, 2012 | 04:44 AM
TheePlaymaker's Avatar
TheePlaymaker
There isn't a pan on the 5 speed and I wouldn't suggest using anything but synchromesh in these manual tranny's anyways.
I wouldn't worry about it at all just make sure you take it easy. I'd worry more about brakes than blowing up your transmission. It might not be that fun with the V6 and your rear end ratio but you should be fine.
Old Apr 25, 2012 | 09:52 AM
00DakDan's Avatar
00DakDan
Section Moderator
You'll be fine.
I might put more weight in the bed instead of the trailer but it's not really that much weight.
Just keep the rpm's up a bit and use 4th more. You'll be fine.
Have a good trip.
Old Apr 29, 2012 | 08:08 PM
moe7404's Avatar
moe7404
i didnt know it is a manual trans. i have been using thick fluid in chrysler trans for a long time no trouble. i know you think old moe is crazy, but my auto trans will longer than yours.
