White smoke at high rpm
Old May 19, 2012 | 05:54 PM
Johnn123's Avatar
Johnn123
Exclamation White smoke at high rpm
Hey after extensive searching (unless im a blind idiot which could be the case) I couldnt come up with an answer to why I'm blowing white smoke at high rpms. Was coming home from work today and decided to leave a nice black mark up my street. Looked back and saw nasty white smoke coming from under the truck where my tail pipe cuts out. This also occurs when I rev it up to 4-5 k rpm. Other than that white smoke never appears. Any idears?
Old May 20, 2012 | 02:32 PM
moe7404's Avatar
moe7404
1. do NOT rev more than 3k rpm with no load. 2. this is just a guess. the piston rings are floating and letting oil by. my guess again, you rev the engine a LOT. this weakened the rings. STOP REVING SO HIGH!!!!!!. you dont need to rev it like you are in race. iam a old guy but i remember this, from the early 60s. chrysler made some great race cars, wax wedge ect. they ALL came with a note stating to not run at top rpm for more than 15 seconds.
Old May 20, 2012 | 04:48 PM
Johnn123's Avatar
Johnn123
I barely ever rev the engine, I only discovered this after I bought it. Ive never had it rev high for more then 2-3 seconds. I drive the thing easy lol never more then 50 mph on regular in between town roads and 60 mph on highways Would make sense though as this thing burns oil like none other.
Old May 20, 2012 | 05:24 PM
fhadso's Avatar
fhadso
Get a Seafoam Spray treatment. Follow the instructions TO THE LETTER. It should burn the excess carbon. Change your oil. Check your spark plug boots to see if there is oil in the wells. If so, change the valve seals (not difficult or expensive). Change your spark plugs while you're at it.
If smoke is pouring out, something is burning that doesn't burn at low temperatures. This could be oil, carbon, something else. Just give your engine a once-over with Seafoam Spray (it goes in the intake instead of the brake booster line) and change your oil and spark plugs, you should be fine.
Old May 20, 2012 | 05:26 PM
fhadso's Avatar
fhadso
15 Seconds is a long time for an engine. I'm sure he only revved it for 4-5 to notice the smoke. It doesn't take much to replicate a problem, especially one like his.
Old May 20, 2012 | 07:31 PM
moe7404's Avatar
moe7404
glad to know you dont over rev it. are you using that water they pass off as oil? i dont like thin oil. i use valoline premium blue heavy duty 15w-40 reg oil. it has the zinc you need. its as thick as i will run with the Kansas winters that we have. the premium blue is factory fill on the Dodge diesel.
Old May 20, 2012 | 07:50 PM
Johnn123's Avatar
Johnn123
I run mobil 1 10w-30 dino oil. I dont think the PO changed the oil very often in it, perhaps that caused it?
Old May 20, 2012 | 08:23 PM
Johnn123's Avatar
Johnn123
Will try the seafoam. Been meaning to change spark plugs for a while now so will def check that as well.
Old May 20, 2012 | 09:39 PM
moe7404's Avatar
moe7404
if that doesnt work try running MMO in the gasoline. run it all ways in my V-6. keeps the pistons, and valves, sealed. and there is a upper luber that puts MMO in the intake, http://www.ampcolubes.com/
Old May 20, 2012 | 11:23 PM
Johnn123's Avatar
Johnn123
I run regular leaded in mine so I dont think that stuff will help, or so the website says. Will get a can of seafoam and try it out.
