wheel bearings
Old Jun 4, 2012 | 05:50 PM
sxrsil3nt's Avatar
sxrsil3nt
Oh yeah I noticed here you're supposed to replace the axle nut?
Why is that - I can understand the pin but why the whole nut?
Old Jun 4, 2012 | 07:21 PM
00DakDan's Avatar
00DakDan
Section Moderator
The nut is designed to "lock." Once it's been used you replace.
Old Jun 4, 2012 | 07:50 PM
GreenDakotaKid's Avatar
GreenDakotaKid
i just looked at the 2000 durango FSM for the hub replacement and it only says to replace the axle nut on the 2WD models. Under the 4WD section it just says to tighten to 173 foot pounds. here is the link to the 2000 durango FSM i was looking at http://www.dakota-durango.com/forum/showthread.php?t=150888
the hub replacement section is under the suspension section
Old Jun 4, 2012 | 08:26 PM
00DakDan's Avatar
00DakDan
Section Moderator
The procedure is different for a 2 versus 4 wheel drive and different torques. Trent asked about an '01 Dakota 2wd. 185 foot pounds is straight from the manual for a 2wd version.
173 foot pounds is correct if you have 4wd.
Old Jun 4, 2012 | 08:52 PM
sxrsil3nt's Avatar
sxrsil3nt
Alright - I have a 4x4 and need to replace a hub as well, just want to know if I need to purchase a new nut.
Old Jun 4, 2012 | 10:01 PM
00DakDan's Avatar
00DakDan
Section Moderator
I don't have a 2002 manual. In the 2001 manual for the 4x4 it says nothing about replacing the nut.
On the 4x4 the axle shaft is splined into the hub, all the nut does is hold everything tight. There is NO rotational force exerted on the nut. There is a cotter pin too.
In the 4x2 the spindle doesn't rotate at all. Big difference. The nut has to not only hold the hub on but not rotate and change the preload on the bearing. You need it to lock in place.
You can certainly replace the nut if you want but it does not appear to be required by Dodge.
Old Jun 6, 2012 | 05:18 PM
Trent479's Avatar
Trent479
from my knowledge you dont have to replace the nut on 4x4's. which to me seems strange because i dont see the diffrence. i will be replacing the nut on mine as it is a 2wd.
Old Jun 6, 2012 | 08:42 PM
RYCOMA79's Avatar
RYCOMA79
well my timkin Bering never came with a new nut and when I enquirer about it I was told it was fine the nut on the truck says not to reuse as it was never tourqued down (prev. owner tightened hand tight or something) my bolt has a nylon insert in it but nothing to lock it place. no cotter pin or space to deform edge
Old Jun 29, 2012 | 12:54 PM
sdfdesign's Avatar
sdfdesign
again the forum proves to be useful ... I am gonna replace hub on my 4x4 this weekend and am happy to hear I don't need to buy a replacement nut. Thanks for the info!
