no reverse lights, but have 12 volts?
Hey guys, i'm confused i have a 99 Dakota 5.2 4x4 and my reverse lights do not work at all, they worked sometimes, then stopped, i put new bulbs in and nothing, tested for power at the bulb socket and there is 12 volts!! but.. as soon as i put the bulb in the voltage drops to 0 volts and the bulb does not light up.. i'm really confused, if anyone has any ideas let me know. Thanks i appreciate it!
the automatic 4 speed, i used the sockets ground also i've tried grounding the bulb on another surface and still nothing.
In '00 there is a connector towards the back of the LH front fender that feeds both the backup lamps. There is also a connector at each lamp themselves. Check at these points, it may have some corrosion present if you're getting voltage.
It's a violet with black tracer wire.
Check the fuse for corrosion too.
Trending Topics
