Crazy Idea for my Dakota!!!
Old Aug 2, 2012 | 07:11 AM
  #31
Dakotaquad's Avatar
Dakotaquad
Yes a very big challenge but going to be fun *** hell if i can pull it off.
Old Aug 14, 2013 | 08:53 PM
  #32
Dakotaquad's Avatar
Dakotaquad
well for an update my crazy plans have been at a stand still cause of the lack of work. lack of work means no money to spare so thats y u guys havent seen any updates in a while. But it seems like my work is starting to pick up so i should be able to start saving up to start the project. hopefully i will have atleast the funds to get the donor truck and gut the truck. btw i was look at acouple of dodge rams thinking about what dodgeramguy85 said and i think if i get the ram frame i can resize the frame to fit the dakota panels to keep the look .
Old Aug 15, 2013 | 10:52 AM
  #33
cpberry1's Avatar
cpberry1
Gotta say I'm really enjoying my Cummins swap after about 10,000 miles - '99 extended cab 5-speed. Seeing 26 mpg regularly. It's a 4bt in the standard engine compartment so not nearly as complicated a swap. Mid-engine is an interesting idea, but sounds like 10x the work...
Patrick
Old Aug 15, 2013 | 04:25 PM
  #34
Dakotaquad's Avatar
Dakotaquad
yeai know its going to be a ton of work ive had a friend start making some drawing with the cad program he has so it should be interesting.
Old Aug 15, 2013 | 08:06 PM
  #35
chris1996's Avatar
chris1996
well I dont have the dakota anymore but I will keep here for seeing all those amazing proyects.
Good luck for everything
Greets from Costa Rica
Old Oct 17, 2013 | 07:43 PM
  #36
dustytrail333's Avatar
dustytrail333
So question. Can I put a 5.9 Cummins into my 91 Dakota without doing all the stuff he wants to do? I don't wanna move my motor or anything just wanna convert to the 5.9 Cummins is it possible?
Old Oct 17, 2013 | 10:01 PM
  #37
dodgeramguy85's Avatar
dodgeramguy85
Will need to beef up the suspension(straight axle) Thats why I said its better off to get a ram frame and adapt the dakota body onto it. Plus its also way stronger. You will be able to tow way more than the stock dakota could(since the frame is light duty)
