Air Conditioner Compressor Clutch NOT Engaging
Old Aug 6, 2012 | 11:51 AM
98DAKAZ's Avatar
98DAKAZ
Default ?
OK not getting the point even if you hot wire it have you seen the compressor turn at all with the engine running that is if you try and hear a squealing noise as you try then the compressor is frozen up
Old Aug 6, 2012 | 11:55 AM
Crazy4x4RT's Avatar
Crazy4x4RT
You have to find where it has power and what doesn't. Start with the wiring diagrams and work your way back from the compressor. To the AC switch or fuses ect. The wiring diagrams are in the factory service manual in the stickies in this section. Or the FAQ in this section in the FAQ.
Old Aug 6, 2012 | 11:59 AM
98DAKAZ's Avatar
98DAKAZ
Default !
If he hears it click in the clutch then its working the wiring that is now the clutch may be weak and not have the power to hold it.
I suspect his compressor is Toast
Anytime your Freon is lost and you try to hot wire it you could roach the compressor ASAP if you run it that way for to long
Old Aug 6, 2012 | 12:05 PM
98DAKAZ's Avatar
98DAKAZ
Default you should
You should look at it this way you never want to run out of engine oil do you? Well the same with an A/C compressor no Freon no oil to keep it running. You can test it a few times without damage but never for too long.
Old Aug 6, 2012 | 12:07 PM
bakerderek0's Avatar
bakerderek0
When I did a test on the compressor clutch, I had the motor running, unplugged the clutch power connector & hotwired it to the battery for maybe 15 seconds. There was no squeiling or abnormal noises. The clutch engaged & the compressor turned like normal.
Then I hook the clutch connecters back up & jump both sensors. Turn the **** in the cab & all I get is a click from the compressor clutch relay.
Old Aug 6, 2012 | 12:10 PM
00DakDan's Avatar
00DakDan
Section Moderator
The wiring for the clutch goes --
Fuse - a/c clutch relay - compressor clutch - ground.
Double check the fuse. There are two for the system. One trips the relay (10 amp) and the other works the clutch (20 amp).
Try a different a/c clutch relay, or jump pins 30 and 87 on the relay to bypass. They can fail too.
Old Aug 6, 2012 | 12:15 PM
98DAKAZ's Avatar
98DAKAZ
Default ???
Now you say it will turn?
I believe he said he changed the relay.
Yikes I wish these guys could be accurate in what they say.
00DakDan he is all yours
Old Aug 6, 2012 | 12:16 PM
98DAKAZ's Avatar
98DAKAZ
Default 00DakDan
00DakDan your sig is still not done correct all I see is a link.
You need to click on the insert pic icon then paste the pic link in that not paste direct into the post box
Old Aug 6, 2012 | 12:23 PM
bakerderek0
I saw on another thread someone having a similar issue and he was asked if his horn worked, but the asker didn't say why. The horn on my truck does not work.
Old Aug 6, 2012 | 12:29 PM
00DakDan's Avatar
00DakDan
Section Moderator
The horn and a/c clutch share a fuse.
In the junction block under the dash, #4, 20 amp.
