Dakota 2004 - Vibration Problems
Old Aug 15, 2012 | 10:06 PM
TonyDi's Avatar
TonyDi
Default Dakota 2004 - Vibration Problems
Long time follower, first time posting.
I just changed the rotors, pads, and tie rods on my 2004 Dakota 3.7 V6.
Truck runs fine but it vibrates when I barely touch the brake pedal. If I apply more pressure the vibration goes almost away. Any idea on what it could be?
Any help would be appreciated.
Thanks.
Tony
Old Aug 16, 2012 | 10:23 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I will move this to the 2nd generation Dakota sub-forum.
Old Aug 16, 2012 | 10:45 PM
dakotaguy1994's Avatar
dakotaguy1994
possibly ball joints?
Old Aug 16, 2012 | 11:01 PM
magnethead's Avatar
magnethead
loose brake pad. no brakes = floats, full brakes = pushed into piston/seat, partial = bouncing around.
We had this problem on the camaro when we first got it, the outside pad would go in fine, but would pop out of it's place and sit skewed...gouged the rotor and sliced the pad at a 30 degree angle.
If it was a warped rotor, it would do it at all times
Old Aug 16, 2012 | 11:28 PM
TonyDi's Avatar
TonyDi
Magnethead thanks for replying.
Will work on the truck this weekend. Any tip on how to identify a loose brake pad?
Should I look for any particular sign of wear?
Thanks.
Old Aug 16, 2012 | 11:36 PM
TonyDi's Avatar
TonyDi
Dakotaguy1994,
Correct me if I'm wrong. I believe the Dakota has upper and lower ball joints right?
Would you change the lower ball joints first or the upper ones? Or should I change both at the same time?
Also is an alignment required after changing the Ball Joints?
Thanks.
Old Aug 16, 2012 | 11:41 PM
98DAKAZ's Avatar
98DAKAZ
First the pads need to snap in a good loud snap I’m wondering if you forgot one of the retaining clips that hold the outside pads.
On ball joints all at one time and yes you will need an alignment
Sometimes if my truck is not used for a few days my brakes will do this the first few times then be fine.
Old Aug 16, 2012 | 11:50 PM
98DAKAZ's Avatar
98DAKAZ
TonyDi
Are your calipers the dual piston type if so you may have a bad piston on one side?
I’m not familiar with the dual piston calipers but that makes sense to me.
Old Aug 17, 2012 | 11:51 AM
Tom A's Avatar
Tom A
Section Moderator
I know it sounds silly, but have you tried rotating your tires?
Old Aug 17, 2012 | 03:47 PM
00DakDan's Avatar
00DakDan
Section Moderator
Did you do the back brakes as well? Drum or disk in the rear?
