My truck
Old Sep 10, 2012 | 06:36 AM
mmguy18's Avatar
mmguy18
Talking My truck
Old Sep 10, 2012 | 05:11 PM
Brian_'s Avatar
Brian_
looks pretty badass, you do the lift yourself?
Old Sep 10, 2012 | 08:48 PM
mmguy18's Avatar
mmguy18
Thanks. I have done everything my self expect for the dual exhaust.Bought it stock Feb 2011. I have added the exhaust,body lift, 2 inchs blocks in the back,new control arms, tie rods,hub bearings,radiator,lower steering shaft,brakes all around,Rancho 5000's all around,Westin nerf bars,Just did the spark plugs and a new Map sensor.
It does still have worked to be done. When I bought it had some running boards on it and I replace them with the nerf bars. The running boards do a fair job of trapping water and I got some holes and rust to deal with. It is underneath so it is not very noticable.
Old Sep 10, 2012 | 10:14 PM
BCdakotaboy's Avatar
BCdakotaboy
Dang!, that's a sharp looking dak. Good feeling of accomplishment doing most of the work yourself. Nice work!
Old Sep 11, 2012 | 11:00 AM
rwilhelms's Avatar
rwilhelms
All I can say is I'm jealous. I wish I had a lift and duals and nice tires but my money has places more important to go than my truck unfortunatley.
Old Sep 11, 2012 | 05:58 PM
mmguy18's Avatar
mmguy18
Understand. Took me 18 months To get this far. Doing the install my self helps. Spent more than I should on the exhaust but other than that. Just a matter doing what I can when I can.Still a loose upper steering shaft and some body work I need to deal with. Wish I could just go out get what I need but sometimes you have wait a little.
Old Sep 11, 2012 | 09:59 PM
BCdakotaboy
So true, been working on mine for 2 years and still a long way to go. Luckily have had no major problems, keep up with regular maintenance and she runs fine.
Old Sep 12, 2012 | 11:27 AM
rwilhelms's Avatar
rwilhelms
I guess I shouldn't complain. I've only had mine since May and I've done the little stuff headlights tail lights and cab lights and gutter mesh grille inserts. I was in need of new tires and was going to buy brand new ones when I found a set of barely used ones on the same rims as you on craigslist for $300. I couldn't pass them up. I had them sand blasted and spray bombed them black. Hopefully I'll get them on this weekend. I hope slowly I'll get as far as you.
Old Sep 12, 2012 | 01:01 PM
mmguy18's Avatar
mmguy18
That is what it takes sometimes. New doesn't mean better. A little time and hard work used can be just as good if not better. I try to focus on cleaning and bringing back to life what I already have.
Old Nov 29, 2012 | 11:40 AM
scomike's Avatar
scomike
What kind of headlights are those? How do you like them?
