2001 Dakota R/T
Old Sep 11, 2012 | 08:19 PM
TREX700's Avatar
TREX700
Default 2001 Dakota R/T
I own a 37,000mile R/T Been siitin for many years Now I crank it after a 7 month sit and the brake light is on. Brakes and ABS on. Whats up. I need help to cut them off. She is a Shop queen waiting on my son to get old enough to drive. Now this. Used to crank ,and run. No lights ever on. HELP
Old Sep 12, 2012 | 12:20 PM
moparman_2004's Avatar
moparman_2004
last time i had those lights on my ecm was bad. does it start and run?
Old Sep 12, 2012 | 08:16 PM
bpark8824's Avatar
bpark8824
I wish I was a kid with a dad waiting to give me his R/T Dakota!!
Your problem could be the speed/abs sensor over the rear differential. Does the speedometer work correctly?
Old Sep 12, 2012 | 09:19 PM
dodgeramguy85's Avatar
dodgeramguy85
Im thinking a wheel speed sensor or low brake fluid
Old Sep 12, 2012 | 09:46 PM
00DakDan's Avatar
00DakDan
Section Moderator
Check for codes. If it is the speed sensor it should throw a code, P0500.
Old Sep 13, 2012 | 07:06 AM
TREX700's Avatar
TREX700
Smile
Yes it does run. Starts right up, and goes into an idle. I need to drive it but the back of it is used for storage at the moment. The battery was allowed to die once, and was replaced with new, I let it get real low would not start. jumped it with extra battery, had trouble idelin. I unhooked the battery put it on charge to full capacity then hooked it up. She fires right up goes into choke mode, and runs until warm ,and idles perfect. I think allowing the battery to go caused this. Than you for your help.
Scatcat
Old Sep 13, 2012 | 07:09 AM
TREX700's Avatar
TREX700
Smile
Didn't mean to hit the button twice.
Old Sep 13, 2012 | 07:12 AM
TREX700's Avatar
TREX700
Thanks for all the help. It does run. As long as it has been sittin in its house. I did let the original battery die, and I bought a new one, and I did let it get low twice. Charged it up put the wires back on. She cranks right up but the lights stay on. Maybe I should get some ins on it, and take it on a 100 mile sprint? Thanks to all of you.
Old Sep 13, 2012 | 07:36 AM
98DAKAZ's Avatar
98DAKAZ
You can get rid of double posts just as long as you are logged in go back to the one you want to remove and delete the text you can’t delete the post.
Just click the edit button
Then leave blank or some just put (bump)
