Removing the wheel well insert Help 98 Dak
Old Sep 12, 2012 | 01:07 PM
98DAKAZ's Avatar
98DAKAZ
Question Removing the wheel well insert Help 98 Dak
Has anyone ever removed there wheel well plastic shield to work on their front suspension I’m thinking of doing this to replace my front bushings.
Is it easy or worth doing?
Was it easy to find replacement plastic pop rivets to put it back?
Any suggestions hints on doing this
Thanks 98DAKAZ
Old Sep 12, 2012 | 01:13 PM
mmguy18's Avatar
mmguy18
There are some push tabs things around it to pop the inner shield out. Does make it easier, but can be a pain to get back in right.
Old Sep 12, 2012 | 01:21 PM
98DAKAZ's Avatar
98DAKAZ
My shields covers up the back bolts for the top A-arm removal almost no room at all but the front has tons of room I could just get to them from the top through the engine bay on the passenger side but on the divers side all the ABS brake crap is in the way kind of sucks
I will get some pic's in a few
Old Sep 12, 2012 | 01:50 PM
98DAKAZ's Avatar
98DAKAZ
This is my passenger side
Shield is covering everything at back of shield
The same side but you can see the front is ok easy getting to the bolts
This is same side looking down into the engine bay tight but ok
Wow one of my foam shields came off hum need to grab that.
Drivers side back of shield no room to work
same side front with lots of room
same side looking through the front of engine bay decent room
Old Sep 12, 2012 | 02:12 PM
98DAKAZ's Avatar
98DAKAZ
Unhappy
As you can see these bushings are needing replacedment.
Old Sep 13, 2012 | 05:33 PM
98DAKAZ's Avatar
98DAKAZ
Talking
Well I decided to remove them I grabbed me a box of rivets and I’m ready to go.
$7 a box of 50
Old Sep 13, 2012 | 06:21 PM
00daksport25's Avatar
00daksport25
when i did my bushings i just worked around it. a pain in the rear, but not impossible. if i ever do it again i'll definitely remove it.
Old Sep 13, 2012 | 08:23 PM
sxrsil3nt's Avatar
sxrsil3nt
Good job, I was gonna say just rip the friggin thing out because 14 year old rivets are just bound to give you trouble. I took my passenger one off when replacing the CPK(s?) and it was more trouble trying to put them back in cause they were so worn.
Old Sep 14, 2012 | 05:30 PM
98DAKAZ's Avatar
98DAKAZ
This is strange I decided to get all the big side bushing nuts lose on my top control arms just to test how hard they may be today and they were loose unless I just gained super human strength just a little tugging and they came loose with ease. Even one of the bushings looked like it was coming out with extracting the big nut that kind of freaked me out.
I tested the bottom ones also and they were the same very easy to turn off.
These are torqued on with some force like 130 lb of torque.
Would this be normal after 14 years?
Old Sep 26, 2012 | 03:55 PM
98DAKAZ's Avatar
98DAKAZ
Thumbs up Yes removing the wheel well shield is Worth it
Removing the wheel well shield is a great thing to do if you need to work on your suspension like replacing your control arm bushings.
Worked great makes the job way easier you can get too everything with ease.
