Wanting to modify my Dakota Sport.
Well most on this forum are back east I have only seen about 4 in this area and they are from the Phoenix area not Tucson.
I have been on this forum over a year and that is the most I have seen on here 4 in the Phoenix area.
http://maps.google.com/maps?hl=en&tab=ll
my plan
I currently have a V6. The truck needs more work then its really worth. I've got a compressioin leak, a power steering leak, a clogged heater core, and can't drive uphill faster then 35 mph. I want to start by fixing these issues. I plan on putting in a body life and repainting it. With the current transmission I'm running in 5th gear by 35 mph, is there a way to change this?
Trending Topics
Here is something to try that is simple and cheap.
Pull all your spark plugs remember were each wire goes now pour about 2 oz. of mmo in each sparkplug hole with a funnel hand crank the engine over a few times let sit for 1 hour repeat always add 2 more oz. of mmo on last one pour the mmo in but don’t turn it over now let sit overnight.
Install all sparkplugs and wires start it up.
The mmo will free up any stuck piston rings if stuck and give you back the power you lost if it was stuck rings that is.
Worth a try and cheap $5 just a little work
mmo is Marvel Mystery Oil at most walmarts
