TPS Wires chewed
Old Oct 6, 2012 | 08:19 PM
  #21
jms2k's Avatar
jms2k
Ok, 6 hours later, my TPS is connected! Wiring, hoses, etc all put back where they belong. AND SHE RUNS! I can take my foot off the gas and she doesn't die on me anymore. What a relief. I ran diagnostics and got no error codes, which is good. Downfall, my Instrument Cluster still doesn't work. I'm guessing I just need to get a new one.
Old Oct 6, 2012 | 08:23 PM
  #22
jms2k's Avatar
jms2k
Also, 100% positive it was squirrels that chewed through the wires. Once I got the bundle pulled up, empty acorn shells fell out. I noticed a few other ground wires by the headlights (on the drivers side as well) that were chewed through. Working on getting those reattached now. It got COLD out there!
Old Oct 6, 2012 | 09:14 PM
  #23
jms2k's Avatar
jms2k
I feel like I'm spamming my own thread. I found a cluster on ebay for $48.99.
http://www.ebay.com/itm/Dodge-Dakota...ca33e2&vxp=mtr
Should I go ahead with it?
Old Oct 6, 2012 | 10:52 PM
  #24
gertie240's Avatar
gertie240
does yours look like that? the desciption says w/o tach but it is a picture of one with a tack. fifty bucks isnt that bad and if you pay with paypal at least you have some kind of garauntee
Old Oct 6, 2012 | 10:57 PM
  #25
gertie240's Avatar
gertie240
did you find a yard? what are the chances the wires to the cluster are chewed somewhere?
Old Oct 7, 2012 | 12:00 AM
  #26
jms2k's Avatar
jms2k
I'm fairly certain the cluster wires are all intact, but I will check them again.
Old Oct 11, 2012 | 09:16 PM
  #27
jms2k's Avatar
jms2k
Ok, just got back from Milwaukee. I checked the voltage to each of the instrument cluster wire harnesses. Here are the readings:
Left (Silver) Connector:
Code:
Left / Right
0 / 0
0 / 26v
28.8 / 0
0 / 0
0* / 0
*when I turned headlights on, jumped to 26v
Right (Black) Connector (which I think powers the actual gauges?):
Code:
Left / Right
2.2-3v / 0
2.5v / 0
0 / 0
0 / 29.8v
29.8v / 0
Does that make sense?
Old Oct 24, 2012 | 02:14 PM
  #28
jms2k's Avatar
jms2k
Good News / Bad News...
Good news: I have obtained a "new" instrument cluster.
Bad news: Still no dice. I didn't have my iPad with me over lunch, so I was unable to run diagnostics. I'm hoping after work I can try, but time is limited. We have a showing on our house tomorrow and an almost 3 year old who doesn't care.
Old Mar 9, 2013 | 11:23 AM
  #29
jms2k's Avatar
jms2k
I FIXED IT!
I found this: http://www.justanswer.com/dodge/5mx2...t-cluster.html
Checked the voltage at 2 and 6, everything looked fine. Checked the grounds at 4/5 and found that 4 wasn't giving me any readings. I ran a new ground to that cavity, and the cluster started working again!
Ticks me off that it was something as simple as that, but it's working! Now to find a buyer... :-( Don't really want to sell it, but I just got a new job that will require some commuting, and I can't afford the gas in the truck.
