Transmission - Dealer Can't Figure It Out
Old Sep 24, 2012 | 01:46 PM
  #21
Tj-dakota's Avatar
Tj-dakota
Master tech - thanks for your thoughts and expertise.
I am looking into getting it done at a shop. Though the overhaul looks like it would be cool project, it looks like getting it in and out would be quite a bear given my resources. This discussion appears to be about my same engine and transmission - http://www.dakota-durango.com/forum/...ad.php?t=93690
What do y'all pay for a overhaul or Chrysler refurb transmission?
Old Sep 24, 2012 | 08:04 PM
  #22
dolittle's Avatar
dolittle
I had the transmission in my D rebuilt for just over 2K
That was with a new toque converter and electrics.
Old Sep 24, 2012 | 10:31 PM
  #23
master tech's Avatar
master tech
Site Moderator & Tech
I think the going price is between 2 to 3k. But it depends on the shop labor. If you did your own repairs, it may get to 500.00.
Old Sep 25, 2012 | 08:03 AM
  #24
Tj-dakota's Avatar
Tj-dakota
I am buried at work right now, but I think it would be a really cool project. Without a garage, transmission jack, etc. I will probably end up taking it in.
Quotes are coming at 1800 without a new oil pump and torque converter. 2800 with them. Sounds like it is in the ball park y'all are saying.
I assume that I should probably do the oil pump and torque converter while I am in there... I think i will start a new thread on whether or not to ask them to put in a shift kit.
Old Sep 28, 2012 | 06:56 AM
  #25
Tj-dakota's Avatar
Tj-dakota
Thought I would come back and give you all an update. I found a local transmission shop with an experienced mechanic. He suggested that we replace the governor solenoid and a sensor before we try a rebuild. Cost about 125 in parts and 75 in labor. Just had to remove the pan to do it. Everything is working great right now. I will keep a close eye on it for the next couple of weeks.
Thanks to all for your input, very much appreciated.
Last edited by Tj-dakota; Sep 28, 2012 at 07:39 AM. Reason: Spelling, Clarification
