lowering ideas
Old Sep 25, 2012 | 07:23 PM
clappe85's Avatar
clappe85
New Member
Default lowering ideas
i own a 2001 dakota sport 3.9 v6 ext. cab. i was thinking about lowerin it a little bit, however, i have never done this befor nor seen it done. i was wondering what kind of process this is and if it is worth it or not. any sugestions would help.
Posted from Dodgeforum.com App for Android
Old Sep 25, 2012 | 07:47 PM
mmguy18's Avatar
mmguy18
I think they look better lifted. Sorry can not help.
Old Sep 25, 2012 | 07:58 PM
00daksport25's Avatar
00daksport25
I've been thinking of doing the same thing. Check out Belltech. They make a lowering kit for our daks.
Old Sep 25, 2012 | 08:14 PM
clappe85's Avatar
clappe85
New Member
ya ive looked up many difderent kits. ive also done some research on it as well, and ive heard tht you need to notch out the frame im looking to see what is all involved in the process.
Old Sep 25, 2012 | 09:43 PM
00daksport25
You're talking about a C notch. That's for people who slam their trucks. Are thinking of slamming your truck? If that's the case you'd probably want to go to a different forum like customdakotas. this forum is great but i dont see very many people lower their dak here.
Old Sep 26, 2012 | 10:32 AM
clappe85's Avatar
clappe85
New Member
well i dont think i want it slammed to the ground but i would like to have it lowered a little bit. something like 3" in back and 2" in the front
Old Sep 26, 2012 | 12:07 PM
1999R/T's Avatar
1999R/T
If your looking for a fairly cheap option, you could do lowering blocks in the back, and could go the correct route and buy 2" drop spindles for the front, or you could cut the coil springs and try to get that 2" drop.
Old Sep 26, 2012 | 08:26 PM
00daksport25
You can get shorter coil springs and softer leaf springs. if ride quality is an issue then buy a lowering kit, it comes with everything you need including shocks.
Old Oct 4, 2012 | 05:58 PM
clappe85's Avatar
clappe85
New Member
so ive decided that this is something that i want to do. i would like to know from someone that has done this is it really a pain in the *** or is this something that can be done in the garage.
Old Oct 10, 2012 | 02:40 PM
clappe85's Avatar
clappe85
New Member
So I have decides that I am going to do a 3/2 drop. By putting 3'' clocks in the back and getting 2'' drop springs in the front. I just need to know if I need to put in new shocks or will the factory ones still work? Any info???
