paint help
Old Oct 2, 2012 | 05:59 PM
clappe85's Avatar
clappe85
New Member
Default paint help
i am looking to repaint my 01 dakota sport. i have been doing alot of research online. however, i figured i would try to get some responses from this forum. #1 spray or roll on? #2 type of paint? #3 clear coat or not? sand down after primer or not? #4 sand between clear coats? any other help would be great also. by the way ia am wanting ro paint the entire truck and want it to look clean and shiney.
Posted from Dodgeforum.com App for Android
Old Oct 2, 2012 | 08:24 PM
sxrsil3nt's Avatar
sxrsil3nt
1) Spray. Unless you don't really care about it, then roll on.
2) Up to you.
3)Definately clear coat.
4)Always sand down after apply primer. Then reprime, and sand using a higher grit.
To repaint an entire truck is gonna be price and VERY time consuming. Make sure you do this in a clean garage with no wind. Plenty of vids on youtube on how to do it just watch a few.
Old Oct 3, 2012 | 06:41 AM
clappe85's Avatar
clappe85
New Member
ya i know it is going to be time consuming but it beats paying thousands to take it somewhere to get it done.
Old Oct 3, 2012 | 09:21 AM
sxrsil3nt's Avatar
sxrsil3nt
Oh yeah no doubt.
Just don't expect it to be perfect, and you're gonna get ALOT of orange peel, but just went sand and buff when done and then you can decide if its good or if you're gonna wanna repaint.
I have repainted the fenders on my grand prix and I really recommend making sure you edge off your paint. (Make sure that when you hit the edges you try to get the paint as even as possible so it doesn't peel off and chip.
I would practice on a piece of metal before you touch your truck.
Old Oct 3, 2012 | 06:02 PM
JBs DAK's Avatar
JBs DAK
I just painted my hood. Black. Used dupiplicolor paint shop paint. I put plastic sheeting on all for sides of the garage. Wet the floor. Used a box fan to draw the air out of the garage while painti g. Primer three coats. Jet black three coats. 4 coats of. Clear. D Aed the hood witb 400 grit. Block sanded the primer with 600. Waited 8 days to sand the primer. Waited another week to wet sand the clear with 1000 grit. Then, 1500, then 2000. Now came the buffing. And then polishing looks perfect... until you get to the 50 cent size area i buffed thru! Gotta resand. Paint. Reclear with a special additive mixed with the. Clear so it will blend in with the rest. Sucks. Looks good but it takes a whole lot of time. Goob luck.
Old Oct 3, 2012 | 06:47 PM
clappe85's Avatar
clappe85
New Member
so after wet sanding clear coat did u put another coat on or just buff
Old Oct 3, 2012 | 07:29 PM
sxrsil3nt's Avatar
sxrsil3nt
Never put clear on top of clear.
He wet sanded it with 1000 (I would've used 2000 but thats my opinion) which means it wouldn't have gone through the clear completely, it'll scuff it up but not go through.
From there you just buff until you get that nice gloss.
Old Oct 4, 2012 | 06:04 AM
JBs DAK's Avatar
JBs DAK
I don't have a real good paint gun so 1000. 1500. 2000 was the only way for me to cut the imperfections down to level to buff. What im really saying is lts gonna take a lot of cash to paint. Your investment in the tools and everything that goes with it isnt worth it if your gonna only do it once. I had 4 thick coats of clear because i knew i would be sanding more than i should. You can clear over clear but u have touse a additive to the clear. I just cant think of the name of it. If j was gonna do it just once I would just pay someone else to do it. My op.
Old Oct 4, 2012 | 05:46 PM
clappe85's Avatar
clappe85
New Member
well i got a compressor and spray gun sanders and all the equip. i was a commercial painter for 5 years. so i have aome paint knowledge. mainly my only expense would be the paint. i just have never paintedva vehicle before and i want it to look nice.
