98 Dakota ABS
Old Oct 9, 2012 | 10:21 AM
cffisher's Avatar
cffisher
Default 98 Dakota ABS
Can't get ABS and brake light to go out.. How do I do this. Changed front pads and rotors changed rear shoes . Breaks work great but lights are on
Old Oct 9, 2012 | 10:41 AM
00DakDan's Avatar
00DakDan
Section Moderator
You have to fix whatever is causing the ABS light to remain on.
Did you replace the caliper/wheel cylinders and need to bleed the system? Assuming the basic brake system is in good shape it's probably an ABS issue. Could be a speed sensor.
You need a special scan tool to read the ABS computer codes or a DRB at the dealer. A regular code reader won't do it.
Old Oct 9, 2012 | 11:40 AM
98DAKAZ's Avatar
98DAKAZ
Talking
Have you looked at your rear differential oil at all is it low or have you ever replaced the oil?
This may be a good idea.
Old Oct 9, 2012 | 04:39 PM
cffisher's Avatar
cffisher
Is there any way to check the sencors? OHM meter?? Yes the breaks have been bleed All parts are new(not sencors) those will cost close to $80. so don't want to just through parts at it
Thanks Charlie
Old Oct 9, 2012 | 05:07 PM
00DakDan's Avatar
00DakDan
Section Moderator
All you can do is establish continuity.
Is it 4 wheel or rear wheel ABS? If 4 wheel, check the wiring harnesses from the hubs. The rear wheel sensor may be on your differential. It is in later years, I'm not familiar enough with a '98 to say for sure.
I know it may seem like a waste of money to get it read. But it is by far the easiest solution. You'll know exactly what is wrong with it and won't have to throw parts at it. Some brake shops can do it, the dealer definitely can.
Old Oct 9, 2012 | 09:59 PM
Tom A's Avatar
Tom A
Section Moderator
I had the same problem with mine. I "fixed" it by disconnecting the ABS module. Obviously, I'm not going to advise anybody to disable their antilock brakes, but it did make the light go out and I haven't suffered any ill effects in the year since I did it. YMMV.
Old Nov 1, 2012 | 04:52 PM
chooper2's Avatar
chooper2
Rear ABS sensor should read between 1500-2500 when you ohm it.Don,t know about trans sensor.
I am in the process of repairing mine now.Checking cab unit tonight.Will let you know.Chooper2
Old Nov 1, 2012 | 10:12 PM
RYCOMA79's Avatar
RYCOMA79
also check to make sure you don't have a leak or a lot of air in the line as it will cause the combination valve to slide one way or the other causing both lights to come on and remain on. the combination valve shifts front or back to close off whatever side is leaking front or backs to insure you will have some breaking ability if you get a system leak
Old Nov 2, 2012 | 09:46 AM
cffisher's Avatar
cffisher
Thanks guys should have responded before this ...It was the senceor on the differential.
Thanks again
Old Nov 4, 2012 | 02:34 PM
chooper2's Avatar
chooper2
Just wanted to let everyone know that i finished my ABS repair.I pulled the Cab connector & cleaned it.Then cleaned the cab at the connector.That repaired my ABS light & brake light.Working great.
