Msd 6A ignition box???
Old Nov 19, 2012 | 04:34 PM
chris_r/t's Avatar
chris_r/t
Default Msd 6A ignition box???
should I put this 6a Msd IB in my r/t?? would I notice a difference ? what exactly does the Msd do?
Posted from Dodgeforum.com App for Android
Old Nov 19, 2012 | 06:31 PM
00DakDan's Avatar
00DakDan
Section Moderator
It is basically an electronic ignition module and is supposed to help give you a hotter, longer lasting, spark.
If you had points or an older electronic ignition I can see the benefits of such a system.
I doubt you'll realize any significant benefits, just my opinion.
Old Nov 19, 2012 | 09:07 PM
Tom A's Avatar
Tom A
Section Moderator
I've been thinking about putting one in my truck, too. It seems like it might give a little bit more complete of a burn, which would translate into slightly improved HP and MPG. If you do get one, get the MSD coil to go with it, and please report back on how you like it.
FWIW, I used to have a car with an MSD 7AL-2 on it and you could literally hear the sparks inside the cylinders when it was cranking. That thing threw lightning bolts!
Old Nov 20, 2012 | 12:36 AM
magnethead's Avatar
magnethead
We have a digital7 w/ HVC coil in the camaro. You wanna talk about a hot spark...the coil itself is 5 pounds!
We were playing with a spark plug/MSD7AL3 on the bench one day...had the ignition powered on and turned the distributor one pole...ZING!
Old Nov 20, 2012 | 04:53 AM
chris_r/t's Avatar
chris_r/t
should I get the factory coil in Msd or a blaster coil ( the cylinder lookin ones)?
Old Nov 20, 2012 | 08:53 PM
Tom A's Avatar
Tom A
Section Moderator
Good question. The MSD #8228 coil is the OEM replacement, so it seems like that would be the one to get, but I'm not sure. I can't find one that specifically says it's for MSD ignitions.
