drive shaft broke
Old Dec 9, 2012 | 01:51 PM
MT1020's Avatar
MT1020
Default drive shaft broke
02 3.9 2wd 3.55 geared..mechanic told me the inside is broke..making a popping noise every time I stop and go..also said that aluminium drive shaft is stock...does anyone know if it is and where to find one
Posted from Dodgeforum.com App for Android
Old Dec 9, 2012 | 03:44 PM
UWAdventurer's Avatar
UWAdventurer
Drive shaft failure doesn't seem to be that common, I would try a junk yard.
Old Dec 9, 2012 | 04:18 PM
MT1020's Avatar
MT1020
I was thinking that but they don't warranty any parts and I don't know what condition it is in
Old Dec 9, 2012 | 04:50 PM
00DakDan's Avatar
00DakDan
Section Moderator
It's a driveshaft. There really isn't that much to it.
Replace the u-joints, that's a given, and you're good.
Or, take your existing driveshaft to a driveline shop and get it fixed.
Old Dec 10, 2012 | 01:09 AM
dodgeramguy85's Avatar
dodgeramguy85
The gears in the rear end are broke? Or the ears of the drive shaft are broke? Nothing can go bad on a driveshaft other than broken ears or bad ujoints either way it will be visible
Old Dec 10, 2012 | 09:49 AM
MT1020's Avatar
MT1020
the inside of the drive shaft..that's where the pop sound is coming from..I was under the truck when he looked at it
Old Dec 10, 2012 | 09:56 AM
98DAKAZ's Avatar
98DAKAZ
Can you post any pic's of this damage because there is nothing inside a drive shaft to break as dodgeramguy85 says the damage is on the ends.
Is it a 2 piece shaft is that it?
Post a pic or two please
Old Dec 10, 2012 | 12:56 PM
Robbadodge's Avatar
Robbadodge
The only thing to snap, crackle and pop under/back there is the diff with drive axles. Perhaps the wording is a little off.
OP, is it the rotating shaft you can see under the truck or is it in the rear axle where you can't see it rotate?
I suspect it's the differential and thus the concern of getting one at the scrap yard. We may find out soon enough!
Robb
Old Dec 10, 2012 | 01:02 PM
dodgeramguy85
The only thing inside a drive shaft will be card board or foam. Other than that nothing inside the shaft is broke. I would look a ujoints and inside the diff.
