Dash light color
Old 12-11-2012 | 12:54 AM
ahsnowlover's Avatar
ahsnowlover
Default Dash light color
I've been doing some searching online and on this forum and have't found much help yet. I want to change the lights in my instrument cluster but not sure what color to use. I would like red but I've heard it doesn't show very well. Has anyone done this and if so what color have you found to be the best for our factory gauges? Also is it possible to change the hvac controller lights as well as the headlight switch? Any help would be great, thanks.
Old 12-15-2012 | 02:10 PM
ahsnowlover
any suggestions?
Old 12-16-2012 | 03:00 PM
Robbadodge's Avatar
Robbadodge
Sorry, no clue.
Responding just so you know someone read this.
Old 12-17-2012 | 12:44 AM
moparman_2004's Avatar
moparman_2004
I did blue and i have no issues with it idk about the red i think it would just be too much and yes you can change the ones out for your climate controls i did and the do the led flash deal and dont work some times i gunna go back to regular bulbs sometime soon i would look at www.superbrightleds.com
here is my dash
Old 12-17-2012 | 01:26 PM
sxrsil3nt's Avatar
sxrsil3nt
I'd try maybe a white to go with the colour of your truck?
That might be a little boring to your liking though, I would also try a yellow or a purple.
Is it just as simple as changing out the bulb?
Old 12-18-2012 | 03:20 AM
moparman_2004
yes its that easy the hardest part is getting the cluster out the led bulbs plug right in to the oem bases already installed in the gauge cluster.
flip the cluster over
twist socket base and pull up
grab bulb and pull
get new bulb and push into the base
and twist back into the hole
Old 12-18-2012 | 10:52 AM
sxrsil3nt's Avatar
sxrsil3nt
Oh well that sounds like a quick little mod that I would be interested in haha.
Have ya done your HVAC controls too?
Old 12-18-2012 | 02:33 PM
moparman_2004
yes but im thinking of pulling them they go on and off and dont work right with the leds i believe they call it hyperflash
Old 12-18-2012 | 05:43 PM
magnethead's Avatar
magnethead
I'd have to see how the circuit is designed to understand what doesn't work.
Old 12-18-2012 | 08:01 PM
moparman_2004
from what i understand x amount of voltage is sent to the light and the led's dont use all the power so they shut off and turn on and back and forth
