Dash light color
Old 12-18-2012 | 08:43 PM
magnethead's Avatar
magnethead
Originally Posted by moparman_2004
from what i understand x amount of voltage is sent to the light and the led's dont use all the power so they shut off and turn on and back and forth
If you're referring to the white backlights, they should nominally pull 2.7-3.2 volts [blues draw same]. Amber and green are 2.1-2.3 volts, and reds are 1.8-2.1 volts.
A good LED driver is current based [constant current drive], and only supplies enough voltage to turn the LED's on.
A poor [but more common] LED driver is voltage based [constant voltage drive], and supplies as much current as the LED's need.
if the factory uses a CCD, then you can change the LED's and it won't care, it will just provide less/more voltage as needed.
if the factory uses CVD, then the LED's can become over/under voltaged, and will either not turn on (too low volts) or burn out (too many volts).
Going from white/blue to any other color, a circuit can be modified, sometimes. Going the other direction, you're usually screwed.
Quick Reply: Dash light color
