radio turning off and on
Old Dec 14, 2012 | 05:08 PM
Fjambone's Avatar
Fjambone
Default radio turning off and on
my stereo in my 01 Dakota is going crazy it goes off and on all the time sometimes I have trouble with the blinkers also. Is there a relay that could be acting up and if so where is it?
Posted from Dodgeforum.com App for Android
Old Dec 14, 2012 | 05:35 PM
98DAKAZ's Avatar
98DAKAZ
Talking
The Ghosts of Christmas past you will have some late night visitors soon
Old Dec 14, 2012 | 08:48 PM
00DakDan's Avatar
00DakDan
Section Moderator
Is it the factory stereo or an aftermarket?
What is the problem with the blinkers?
Old Dec 14, 2012 | 11:15 PM
Wes Garrett's Avatar
Wes Garrett
Id venture a guess that it would possibly a BAD Central Timer Module, i could be wrong. id check for fuses and such..
Old Dec 14, 2012 | 11:22 PM
moe7404's Avatar
moe7404
my 2001 does the same. i think its the ignition switch. try wiggling the key.
Old Jan 3, 2013 | 04:54 PM
Fjambone's Avatar
Fjambone
Default ignition switch
I think my ignition switch is affecting my stereo and blinkers. Could it be the switch or the lock cylinder? When a wiggle the keys everything works. It also acts up more when it's cold out.
Old Jan 3, 2013 | 06:49 PM
00DakDan's Avatar
00DakDan
Section Moderator
More likely it is the switch.
Old Jan 3, 2013 | 10:49 PM
magnethead's Avatar
magnethead
I was also going to say ignition switch. Does the overhead console (if equipped) go out?
