Air bag light
Old Dec 18, 2012 | 08:57 PM
mmguy18's Avatar
mmguy18
Default Air bag light
Just replaced the Clockspring and my air bag light is still on. Was told the system should reset its self and the light would go out. Do I need to do something else or do I have a another issue?
Old Dec 18, 2012 | 10:04 PM
00DakDan's Avatar
00DakDan
Section Moderator
Did the horn or cruise control not work?
You probably have another issue. It is supposed to do a self test at key on.
It can be read by the dealer. Most scan readers won't pick up body trouble codes.
Old Dec 18, 2012 | 11:04 PM
Dakotaquad's Avatar
Dakotaquad
could be a loose pin in the plug to the air bag. cause it happens to me everyone once an a while.
Old Dec 18, 2012 | 11:30 PM
mmguy18's Avatar
mmguy18
Horn worked not sure about cruise control (never use it). Broke clockspring when I replace the steering shaft.Had a buddy that did his but it is in a Ford and his supposedly has to be reset by dealer. Everything I have read about Dodge they reset. I assuming I have another issue. Already had in the dealer when had a key fog programed they want $180 to tell what the problem is. This is why I don't like to deal with dealerships. $180 to hook up scanner and tell what the issue is a little outrageous. Wish I could make $180 for 5 mins time.
Old Dec 19, 2012 | 12:36 AM
moparman_2004's Avatar
moparman_2004
have you tryed to pull the fuse and reset the system or reset the ecm
Old Dec 20, 2012 | 03:17 PM
mmguy18's Avatar
mmguy18
I will check the fuses.
Old Dec 20, 2012 | 06:38 PM
sxrsil3nt's Avatar
sxrsil3nt
Have your dash apart recently?
When throwing my sub in I forget to unplug the air bag connection so I yanked a little too hard and thing I damaged the connection.
My airbag light is intermittent and i'm 90% sure its cause I pulled the dash apart.
Old Dec 22, 2012 | 02:56 PM
mmguy18's Avatar
mmguy18
Fuse didn't work. I haven't had the dash apart.Found a little trick other day to reset air bag. May try it in a day or two see if works. Let you know.
Old Dec 22, 2012 | 07:57 PM
sxrsil3nt's Avatar
sxrsil3nt
A little trick?
Please share!
Old Dec 23, 2012 | 12:36 PM
mmguy18's Avatar
mmguy18
Someone had told me about a paper clip trick they had seen on You Tube. Haven;t look yet or try it see if it works. Said to put in search box Airbag light reset
