High Mileage chemicals ?????
Old Dec 28, 2012 | 10:01 AM
Bluedogcards's Avatar
Bluedogcards
Default High Mileage chemicals ?????
HI all,
My truck 2000 SLT 4x4 4.7, it has some good miles on it just over 230000.
It may use a 1/2 qu. of oil between oil changes about every 5000 miles. i have notice a little lose in power, really thinking it my rings, it there any after market chemicals that help.
Old Dec 28, 2012 | 10:46 AM
00DakDan's Avatar
00DakDan
Section Moderator
Hi,
If it is worn rings then no chemical will help. But, you really aren't using any significant oil. Even 1 quart in 1000 miles is considered normal by some car makers
How is the compression? When's the last time you replaced the plugs or air filter? Have the cats every been changed? They do not last forever and can cause a restriction in the exhaust. How about the 02 sensors? They also don't last, they can get lazy, and then the air fuel ratio can be a bit off.
Old Dec 28, 2012 | 11:01 AM
Bluedogcards
Originally Posted by 00DakDan
Hi,
O 2 sensors have been changed less then 15000 on them, plugs are due for new ones,, i do take them out about every 6 months and check them,, air filter is good, i change it every third oil change, new one due on next change. what do you mean by the cats?? Catalytic Converter? thinking it was changed about 80000 miles ago
Not sure about the compression, going to say not bad i do notices loose of power. that's why am thinking rings.. my PVC senser is due for a change after the first of the month
Old Dec 28, 2012 | 11:28 AM
00DakDan's Avatar
00DakDan
Section Moderator
cats - catalytic converter(s). Depending upon what emissions package you have you may have have one or three (two pre-cats).
Increased backpressure will kill performance.
Old Dec 28, 2012 | 11:57 AM
Bluedogcards
see i learned something today, how does one check it, or is it just something that gets changed every so many miles
Old Dec 28, 2012 | 12:02 PM
98DAKAZ's Avatar
98DAKAZ
I would look at the cats first also if never replaced
Have you ever had your fuel injectors hard cleaned either in the engine or bench cleaned some companys can run a very strong cleaner through the injectors and clean them or remove them and clean and adjust them this is the best way I think it runs about $80 to $120.
But make sure that they are doing a hard clean not just dumping something in the gas tank its a special cleaner they bypass the gas tank and directly connect to the fuel rail to clean them so be sure you are getting the real deal.
Old Dec 28, 2012 | 12:08 PM
98DAKAZ's Avatar
98DAKAZ
This will help you understand
Old Dec 28, 2012 | 12:43 PM
00DakDan's Avatar
00DakDan
Section Moderator
A vacuum gauge can be used to diagnose an exhaust obstruction. It will also tell you the overall "health" of the engine.
Old Dec 28, 2012 | 12:49 PM
Bluedogcards
Wow what a great video, some good insite. going to have to see if anyone does them in town, i can't be without a vehicle, i did look into getting new ones about $65 each, having them done is a lot cheaper.
Thanks for all your input on this got some work to do now
Old Dec 28, 2012 | 04:44 PM
moe7404's Avatar
moe7404
Default Mmo
get some Marvel Mystrey Oil. it will clean the engine and seal the rings, it takes a while.
