please help i have a SHORT!!
Old Jan 18, 2013 | 09:50 PM
scjosh's Avatar
scjosh
Default please help i have a SHORT!!
hello everybody out there i have a 02 dakota slt 4.7 2wd
i have a po141 code and its been a real headache.i have gotten other codes too but they have disapeared this is the only code that has stuck my truck had started idling a lil rough i figured out that it was a pcv hose any ways i have a heater malfunction in my driver side bottom bank o2 sensor ive taken it to a specialist and he doesnt know what is going on .
at the fuse box 20 amp o2 fuse isnt working rite when i put my volt meter on it nothing then when i reverse the poles it shows a negitive 12.5 dont know what to do does any one know what to do ??????
i have already replaced the pcm both o2 sensors on that side and i have taken the whole wire harness out for inspection and still found nothing what else can it be, what else can i do
has anybody ever had this happen?
please help i dont want to can my dakota!
Old Jan 19, 2013 | 10:09 AM
00DakDan's Avatar
00DakDan
Section Moderator
i'm basing this off on the 2001 wiring diagram, I don't have an '02.
How are you measuring voltage at the fuse.
If you are reading across the fuse you should read 0 unless it's blown in which case you'll read battery voltage.
The oxygen heaters for all the O2's are fed off the same fuse - 20 amp.
Do you have power to the 02 heater relay in the PDC? You should have power to pins 86 and 30, truck running - see pic below.
Old Jan 24, 2013 | 12:08 AM
scjosh's Avatar
scjosh
I believe it works
I tested the o2 power and ground and their there i found that the right bank always in open loop and front and rear o2 sensors reading stay.06 volt at constant speed or idle i have some momentary fluctuation with applying throttle indicating it sort of works
Po141 due to voltage not dropping to.4_.6 it only goes to.9_1.0
Found very lean right bank o2 sensor reading after warm up and right bank never going into closed loop
Old Jan 24, 2013 | 09:38 AM
00DakDan's Avatar
00DakDan
Section Moderator
What brand O2 sensors are you using?
Old Jan 25, 2013 | 09:41 PM
scjosh's Avatar
scjosh
got one from the dealership it cost 150 bucks oem from the dealership and still threw the code
Old Jan 25, 2013 | 10:42 PM
00DakDan's Avatar
00DakDan
Section Moderator
Ohm out each O2 sensor. At 70, you should be showing about 13.5 ohms resistance on a 4.7.
Do you have a test light? Use that to see if the heaters are getting power. It puts more of a load on the system than a meter.
I've attached the wiring pinout for the O2's. Pins 1&2 are the heater.
Old Jan 26, 2013 | 08:32 PM
scjosh's Avatar
scjosh
I don't get power to my bottom bank driver side
Old Jan 26, 2013 | 09:07 PM
00DakDan's Avatar
00DakDan
Section Moderator
Are you getting power to 2/2? I only ask as they are both powered off of the same relay. If so, check for a bad splice - S179 (see attachment). Then check the grounds, down on the right front by the crank position sensor.
You can always wire the heaters for the downstream O2's together if you have to. That's how they're wired anyways.
Old Jan 27, 2013 | 12:18 AM
scjosh's Avatar
scjosh
I have write brushed clean all grounds well check for the bad splice thank you
Old Feb 2, 2013 | 05:52 PM
scjosh's Avatar
scjosh
No power to the o2 relay and no power to the other bottom bank o2 sensor
