Help Me Find The Leak
Old Jan 22, 2013 | 09:41 PM
  #21
Custer's Avatar
Custer
Originally Posted by Tom A
It still sounds like your water pump may be leaking. Can you wobble your fan at all? If you can, your bearings are probably bad.
Actually I think you nailed it...Sorry!
I just came in from giving the fan a better wobble inspection and it's not solid. I think it's starting to go and a new water pump is in order.
Old Jan 22, 2013 | 09:47 PM
  #22
Tom A's Avatar
Tom A
Section Moderator
Well, that sucks. It's much easier to tighten up a radiator hose.
Old Jan 22, 2013 | 09:50 PM
  #23
Custer's Avatar
Custer
I'm doing search on replacing the water pump without removing the shroud & radiator...Is this possible?
Should I not instal the fan on the new water pump since I have the electric fan?
Old Jan 23, 2013 | 12:36 AM
  #24
Custer's Avatar
Custer
Nice...Replacing the WP was easier than I thought. My awesome wife made a parts run while I started draining coolant and removing the shroud (easy) and the water pump.
I'm going without the mechanical fan for now.
Here's my current question:
The pump has a rubber O-ring-ish gasket, molded to fit the channel/groove in the pump. Do I use RTV sealant or not? I don't see any traces of RTV from before but I'm not sure I shouldn't use something.
Old Jan 23, 2013 | 12:59 AM
  #25
MadisonDakota's Avatar
MadisonDakota
Smart move on the removal of the mechanical fan. It takes 30 seconds to put back on if you decide you don't like not having it.
As far as RTV or not, I have never heard of anyone using it. And, judging by the design of that pump and the groove in the timing chain cover, I would say there is no need for it.
Old Jan 23, 2013 | 09:05 AM
  #26
00DakDan's Avatar
00DakDan
Section Moderator
No on the RTV. The o-ring is the gasket.
Just make sure it is seated properly and you torque it evenly.
Old Jan 31, 2013 | 03:39 PM
  #27
Custer's Avatar
Custer
Well I've been waiting to post an update as not to jump the gun with excitement but I can say my oil (Main seal replaced) and water pump leaks are solved. Any former residue has finally cooked off the block and there's not a single trace.
I saw in another post a guy paid $400 bucks for a "onsite" water pump replacement...I'm in the wrong line of work (Manager with Costco Wholesale). I replace a co-workers radiator and water pump a few weeks ago in his Grand Cherokee for parts and fluid totaling $385 (Which included a Chilton's manual). His highest estimate came back at $1700 from a "trusted" shop, $900 from the dealer. I did it for a Starbucks coffee & a maple bar to help a friend.
Next is a 4 way brake job for another co-worker...Maybe I can get some lunch for that one.
