Help Me Find The Leak
Old Jan 21, 2013 | 04:02 PM
Custer's Avatar
Custer
Default Help Me Find The Leak
I have another thread when this was more oil leak related (solved) but wanted to start this one because I'm betting someone's seen it before.
If you have any information leading to the prevention of this leak please contact me right away...Thanks.
I suspect antifreeze...Photo taken from under while laying on my back looking up at the problem.
Hose? Gasket where the lower hose connects? The top side of the engine is bone dry...I don't see any signs of a water pump failure.
Old Jan 21, 2013 | 04:20 PM
98DAKAZ's Avatar
98DAKAZ
Looks like the rad hose that clamp is old school and not to strong replace with a good clamp and see if it goes away.
You could just pull the old clamp up out of the way then feed the screw kind on by undoing it the and feeding it back together if you know what I mean.
That way no lose of fluid
Old Jan 21, 2013 | 06:36 PM
Custer's Avatar
Custer
Originally Posted by 98DAKAZ
...You could just pull the old clamp up out of the way then feed the screw kind on by undoing it the and feeding it back together if you know what I mean.
I think you're on to something. While trying to slide the old clamp out of the way there was a some fluid seeping from the hose. I'll have to cut the old clamp off (To avoid losing fluid...I want to save the environment) before installing the new one.
Old Jan 21, 2013 | 07:08 PM
00DakDan's Avatar
00DakDan
Section Moderator
It looks like there might be a line of fluid heading to that drip on the harmonic balancer.
I'd really give that water pump weep hole a close look.
Old Jan 21, 2013 | 07:21 PM
MadisonDakota's Avatar
MadisonDakota
Take that mechanical fan off ASAP!
Old Jan 21, 2013 | 09:42 PM
Custer's Avatar
Custer
Originally Posted by 00DakDan
It looks like there might be a line of fluid heading to that drip on the harmonic balancer. I'd really give that water pump weep hole a close look.
I'll give it a closer inspection...Thanks.
Tell me more please.
Old Jan 21, 2013 | 10:31 PM
MadisonDakota
You have an electric fan, correct? All the mechanical fan does is suck power!
Old Jan 21, 2013 | 11:21 PM
Custer's Avatar
Custer
I have an electric fan... Is it enough to cool things down or do I have to install some duel fan mod?
Old Jan 22, 2013 | 12:15 AM
MadisonDakota
I have not had mine on for about 30,000 miles. A lot of other people have done it too. The stock fan comes on if the engine goes over halfway on the temp (i'm not sure the exact temp, but I know it's low enough to not cause problems.) It also comes on when the A/C is on. The second you start moving (5+ mph) the radiator does a perfectly fine job keeping the engine cool without a big ole heavy fan hanging off of the water pump. Your truck will drive a little better too! Try it, it's the dead of winter...nothing to hurt, because it's easy to put back on.
Old Jan 22, 2013 | 12:22 AM
joe002's Avatar
joe002
FYI - I just replaced the upper hose on mine, and the new stock hose came with old school clamps attached to the hose. They had a clip on the clamp to keep it open, and when you get the hose in place you remove the clip and the clamp sets on pretty tight - no leaks at all.
