Oil leaking out by fan help please!
More likely it's a bearing that failed in the water pump, not the shaft, and allowing the shaft to wobble.
Replace the water pump. It's not expensive. If the timing chain cover is damaged, it will be a lot more involved though. More $$$.
Thanks for the help guys
The water pump will fix the wobble, but, the back side of the water pump is the timing chain cover. If it is damaged, you'll need to replace it.
If it's wobbling as bad as you say, and you see oil, it's likely damaged.
That would also allow antifreeze into your oil, not good.
With any old auto opening up the hood at least one time a month is always a good idea to check things out look for potential problems
It can save you a lot of money and hardship to catch anything before it explodes in your face
But may also be an oil/antifreeze mix. Will wipe out the motor in a hurry. In any case, the truck should not the operated until you have removed the water pump and inspected the timing cover for any holes. You are just doing more damage. At the least, you may get away with a new water pump and fresh antifreeze. At worst, you're looking at water pump, antifreeze, coolant system flush, oil change + oil flush (basically 2 oil changes close together), a timing cover, and lots of labor (You may have just enough room to change the cover in the truck without pulling the engine, but it won't be any kind of fun).
He can't inspect the timing chain cover until the water pump is removed.
You can tell if it's antifreeze. It'll have the sickly sweet smell to it. Oil, well, it's oil.
If it's just antifreeze you might just need a water pump. At any point, get it fixed, don't drive it. If that fan comes off you'll have a lot more problems to deal with.
It sure ran down the sidewalk in the snow like antifreeze, but it was also brown-ish. Not the best to be looking at it in the dark
