Overlooked Maintenance Issues..?
Old Feb 2, 2013 | 11:42 PM
5hundo's Avatar
5hundo
Default Overlooked Maintenance Issues..?
Hey guys...
My DAK has almost 180k miles on it, and my wife is going to have to take it this weekend for a business trip. Our other car is a Natural Gas car, and there aren't any CNG stations around the city where she is going to work. So, today, I tackled some of the maintenance stuff that was due, and some of the stuff I had been neglecting. I did the oil, spark plugs, tire pressure, checked trans level (manual), checked diff level, and cleaned the throttle body for the first time (YUCK!).
Here's my question: I have until about 2pm tomorrow to repair some last-minute items. Anything else I should do between now and then? I'm thinking I'll do the fuel filter, and windshield wipers because we might have some rain coming. What else?
Old Feb 2, 2013 | 11:54 PM
98DAKAZ's Avatar
98DAKAZ
How are your rad hoses and how old is the antifreeze the S-belt ok?
Fuel filter is in the gas tank so thats out new wipers would be good
Old Feb 3, 2013 | 12:12 AM
5hundo's Avatar
5hundo
Thanks for the advice, man... Funny you mention the rad hoses; I just blew the top hose a couple weeks ago. Both of those got replaced already. So, unless they have an "infant mortality" problem, I think I'm okay. I can't believe they went 179k miles!
Sux about the fuel filter. Between the fuel pump/filter, and alternator, those are the items I worry about the most. I have never had to replace them. I mean, how much longer can they really last, after 10 years and the equivalent distance of 3/4 of the distance to the moon!?!?!?
Old Feb 3, 2013 | 12:21 AM
98DAKAZ's Avatar
98DAKAZ
Check the back brakes make sure they are adjusted not too tight though maybe just click them in three or four clicks just to snug them up a bit.
Or if you trust yourself crank them in snug then back them out a few clicks you dont want them too tight as the may start binding on you/her if you understand how to back them out that is this can be a hard thing to do.
Old Feb 3, 2013 | 01:41 AM
5hundo's Avatar
5hundo
Thanks. I think they're okay but I'll give them a look. I had to replace a pair of e-brake shoes not long ago because she left the e-brake on, so I replaced the whole unit. I'll remind her again to not drive with the e-brake on.
Old Feb 3, 2013 | 10:16 AM
00DakDan's Avatar
00DakDan
Section Moderator
Don't forget the rest of the cooling system hoses, including the bypass hose if you have one.
Old Feb 3, 2013 | 11:18 AM
98DAKAZ's Avatar
98DAKAZ
Yea the heater hoses
I finally replaced them on my Dak just last year they were 14 years old but looked ok when I pulled them off still flexible not rotted like I thought they would be. Kind of weird as I have changed the top and bottom rad ones three times already but I had new heater hoses so I changed them.
