Oil Drip
Old Feb 11, 2013 | 11:10 PM
00DakDan's Avatar
00DakDan
Section Moderator
When you changed the filter, did you look to see if an old gasket was stuck on the mount? Two gaskets will cause a leak.
Old Feb 11, 2013 | 11:35 PM
Dodgeboy77's Avatar
Dodgeboy77
i'm pretty sure i did , but i don't have a lot of tools and a pan here to take off the filter to check
Old Feb 12, 2013 | 09:45 PM
GM1697's Avatar
GM1697
Old Feb 28, 2013 | 01:31 PM
Dodgeboy77's Avatar
Dodgeboy77
got home, took the filter off, no extra gasket. the leak is just above the filter mounting surface and not the sender. is there a gasket in there?
Old Feb 28, 2013 | 10:02 PM
RYCOMA79's Avatar
RYCOMA79
change the filter. Years ago I had a leak from the filter thought it was a head leak turned out the filter gasket was bad and would leak like hell when it was cold outside.
Old Feb 28, 2013 | 10:52 PM
Dodgeboy77's Avatar
Dodgeboy77
i just changed it. i took the filter off and there is oil above it on the housing
Old Mar 3, 2013 | 02:41 PM
Dodgeboy77's Avatar
Dodgeboy77
called dodge and they said there is no gasket there, my timing cover gasket is leaking. is this right?
Old Mar 4, 2013 | 05:22 PM
Dodgeboy77's Avatar
Dodgeboy77
took it to a local shop today to check for a timing cover seal for sure, they found the oil sensor leaking so it should be fixed now. will check tomorrow for sure.
